HID Advice DDM Tuning
#31
Oh yeah, I had to do that whole thing also, but for the fogs instead of soldering them together, I just soldered each side with a male and female terminal so I can remove it easily if I need to. But no harness whatsoever, I just had to flip the terminals for the ballasts 'cause its reverse polarity, like TechGreek said(but I was warned earlier by the guys from DDM Tuning about it.)
#36
Former Sponsor
Be careful with 55W HID kits. DDM openly admits to using 35W bulbs powered by 55W ballasts meaning that the ballasts are overdriving the 35W bulbs. This will cause the bulbs to burn HOTTER and burn out prematurely. Additional heat may damage your vehicle's headlights.
Steve
Steve
#37
Steve
Steve
Thanks Steve
#38
Here's the thing people, HID were created because the conventional halogen bulb creates heat, not bright enough/brightness is not uniform, high wattage, and pretty much it's old technology. HID is only 35watts originally, and compared to halogen it runs from 55-75watts. So why do you need to get a 55watt HID? To be brighter? Where are you planning to use it? Streets or off-road? The 55watt HID is mainly used for off-road and applications of such, like flashing Batman's logo into the sky, then you'd probably need the 55watt HID.
#39
#43
I usually visit DDM Tuning since they're near my place, they didn't mention anything about stopping selling HID's guys. The back order back then was only a temporary issue with customs and manufacturing from China.
#44
Do you guys get the fat raptor one or the slims for the low beam? They are both the same, just different sizes depending on the room you have in the headlight area. We can fit raptors in there right?
