SC- 1st Gen (1992-2000)
Guys looking to go NA-T
Old 02-03-11, 07:28 PM
xclusive_s
xclusive_s's Avatar
http://cgi.ebay.com/ebaymotors/50mm-...#ht_5217wt_991
and lastly this is the wastegate... I plan on going standalone alas i don't have 1500 laying around
xclusive_s
xclusive_s's Avatar
Old 02-03-11, 07:32 PM
broda805
broda805's Avatar
go with a name brand wastegate... dont cut corners where the outcome would result in you looking for a new motor.
i ALMOST used a ebay no name one but for peace of mind i forked out some more money for something i can rely on
Old 02-03-11, 07:35 PM
jjffyy
jjffyy's Avatar
Those F1 racing clutches should be OK, I've seen a couple of Supraforums members with the kits. I also have the chromoly 1jz flywheel in my R154 and its holding up fine
Old 02-03-11, 07:48 PM
imDementeD
imDementeD's Avatar
i was talking to a guy on SF and he used this turbo for over a year making over 700whp..ive seen a few others using it as well..it seems to be about the same quality as most..a lot of people have had good luck with china turbos such as xs etc...others have had bad luck..it happens..quality control surely isnt as good but id give it a shot..if this guy wants to trade me locally for one of these turbos then ill do it and give it a shot..fk it..
Old 02-03-11, 08:10 PM
lookEVO
lookEVO's Avatar
For 450 you can get an .84 ar t67 with divided housing... hmmm
Old 02-04-11, 05:47 AM
pimpc300
pimpc300's Avatar
subscribed!! gl with the proyect, don't forget to make a price list at the end.
Old 02-04-11, 06:28 AM
nivek5sfe
nivek5sfe's Avatar
for you guys using this set up did you have clock the turbo flange on the manifold in order for it to clear the distributor?
Old 02-04-11, 06:48 AM
Ali SC3
Ali SC3's Avatar
just use a 4runner distributor cap
Old 02-04-11, 07:06 AM
nivek5sfe
nivek5sfe's Avatar
i have a 4 runner distributor cap but some set ups i see still have a 4" to 3" reducer as well as the cap in order to clear and others arent even running any kind of intake cause it looks like it wouldnt clear with either. im just curious as to to close this manifold puts the turbo to the distributor. plus i plan on running a t67.
Old 02-04-11, 08:05 AM
99SC42
99SC42's Avatar
You need a BL manifold, Or distributorless
Old 02-04-11, 09:02 AM
97sc300t
97sc300t's Avatar
Originally Posted by xclusive_s
Thank you sir! if you don't mind me asking what kind of turbo and wastegate did you end up going with? I plan on doing my headgasket as well!! I would like to hit at least the 450 mark
i used an hks style wastegate and used a precision 67gtq
Old 02-04-11, 09:06 AM
97sc300t
97sc300t's Avatar
I used a 4 runner dist. cap and bought modified a 4inch 45degree elbow to clear the distributor-no problems-
Old 02-04-11, 09:34 AM
kyddo112
kyddo112's Avatar
did you have problems with the added height hitting the charge piping?
Old 03-09-11, 08:01 PM
gdoutlex
gdoutlex's Avatar
cant wait for this build to be done so i can check it out when you bring it to the weekly tuesday meet in arlington
Quick Reply: Guys looking to go NA-T
