SC- 1st Gen (1992-2000)
Guys looking to go NA-T
Old 02-03-11, 04:57 PM
xclusive_s
xclusive_s's Avatar
Default Guys looking to go NA-T
http://cgi.ebay.com/ebaymotors/Turbo...#ht_3072wt_939
I plan on using a GT45 dual ball bearing turbo.
Has anyone used this generic manifold setup, any info on its build quality would be great!!
Old 02-03-11, 05:01 PM
97sc300t
97sc300t's Avatar
I did on my setup and it held up great and I made over 500whp-
Old 02-03-11, 05:12 PM
xclusive_s
xclusive_s's Avatar
Thank you sir! if you don't mind me asking what kind of turbo and wastegate did you end up going with? I plan on doing my headgasket as well!! I would like to hit at least the 450 mark
Old 02-03-11, 05:14 PM
TLDriver
TLDriver's Avatar
I have the same setup. The only thing I would do is check that the dump pipe will fit your waste gauge.
vegas_sc4
vegas_sc4's Avatar
Www.godspeedproject.com is decent for manifolds and what not
Old 02-03-11, 05:30 PM
xclusive_s
xclusive_s's Avatar
if you don't mind me asking what's your setup and what kind of ems did you go with? stock internals?
Old 02-03-11, 05:45 PM
SC300_704
SC300_704's Avatar
i got that same turbo manifold and it's holding fine for almost a year of abusing now. but had to cut about 1/2" of the wastegate runner and clock the wastegate flange so it'll fit a ebay 50mm wastegate w/o hitting anything.
Old 02-03-11, 05:54 PM
SChema
SChema's Avatar
When you say GT45? Do you mean a legit GT45 from Garrett?
I've seen quite a few ebay manifolds but they are mainly for the smaller framed T4 turbos. When you say GT45, I picture an 80mm turbo, just about the limits of a T4 from Garrett until you move up to a T6 frame. From what I've seen, the mounting flange is not placed far enough from the head causing a clearance issue with large turbos. Number 1 runner becomes a problem not allowing the compressor housing to clock down far enough for the charge pipe.
A friend of mine is using a generic ebay manifold with a Borg Warner S375 and had the exact same issue. Number 1 runner is currently being re-fabricated to clearance the turbo.
Old 02-03-11, 06:12 PM
xclusive_s
xclusive_s's Avatar
Well this what i plan on doing. Budget build
pic of my girl:
Finished the suspension.. Supra Sprint springs very good springs in my opinion only con is slams the ish out my front and i have to find a tire size that fits. My struts supra tokiko illumina 5 way adjustable
GT45 is from godspeed..i'm poor man in a rich man's sport!
GODSPEED gt45 T4 turbo charger 1.00a w/ NEW ANTI-SURGE HOUSING COMPRESSOR COVER
BALL BEARING TURBO****
Intake :4 inch
Outlet: 2.5 inch
Compressor trim: .70 ar
Compressor Wheel diameter: 66.71 /84.20
Turbine wheel diameter : 63.56 /73.60
Exhaust trim: 1.00ar
Turbine flange type: T4 flange
Downpipe flange type : 3.25" v band flange
Cooling type: oil cooled only
Twin scroll turbine housing (quicker response then single exhaust outlet )
Horsepower rating: 400-600hp+
I plan on doing cometic 1.3 mm headgasket
and walboro fuel pump 255
and some 660cc injectors
I have done the following:
new timing belt and tensioner, water pump, thermostat
Old 02-03-11, 06:20 PM
xclusive_s
xclusive_s's Avatar
This will be my intercooler:
INTERCOOLER SPEC:
polish bar & plate design for better cooling efficiency
max horsepower capacity : 700-800hp
core length 24"
core height 12"
core thickness 4"
inlet / outlet size 3"
end to end length 30 1/2"
Old 02-03-11, 06:29 PM
SChema
SChema's Avatar
First thing that comes to mind, I would recommend staying away from ebay turbos. I'm sure people have make power with it but for how long?
Seems similar to a Garrett GT40 variance that costs about 4 - 5 times as much. Kinda makes you think what they left out to bring the cost down so much. I would honestly say you can spend the $350 somewhere else and don't skimp on the important components.
Anyways, I don't see any issue fitting this turbo on this manifold.
Old 02-03-11, 06:34 PM
lookEVO
lookEVO's Avatar
I like that they offer a warranty... Im a certified mechanic so i would be set. LOL
Old 02-03-11, 06:49 PM
broda805
broda805's Avatar
i used that manifold, got it ceramic coated and so far so good i cut that WG flange off and welded on a precision 46mm thou. and yes stay away from non authentic turbos
Old 02-03-11, 07:14 PM
xclusive_s
xclusive_s's Avatar
i plan on ordering these injectors: http://cgi.ebay.com/ebaymotors/ws/eB...ht_1407wt_1165
quick question guys do we have top feed injectors?
Any opinion on this clutch guys?
http://cgi.ebay.com/ebaymotors/XTR-S...#ht_2326wt_939
Old 02-03-11, 07:16 PM
xclusive_s
xclusive_s's Avatar
My purpose in doing this build is simple...i would like to make a DIY for my NA-T guys thats very reasonable. I'm tired of seeing companines like boost logic try to sell me a kit for 6k when i can piece together a knockoff that will work work just as well 1k. I do realize some of their manifolds can hold say 35psi of boost and not crack but for most of us 10-15 is all we want. Reasonable wheel hp. I would like to help the community and create powerful reasonable car that helps all of us. And i would like to volunteer myself as a test subject! wish me luck gents.
Quick Reply: Guys looking to go NA-T
