2jz GE vs GTE
#46
The N/A doesnt it have different internals then the GTE block?
If so then the safety factor comes in mind. As soon as you through boost to a NA motor you are increasing your chances of detination and the motor going kaboom. I know it might be cheaper to do a NA-T but I think GTE out of an aristo and just swap the trannys. will be my route. Through a front mount on it and some tuning and call it a day.
#47
This is the thread that made me turn to NA-T. Just sayin'
https://www.clublexus.com/forums/gs-...-t-basics.html
#48
my old baby right before i hooked everything up and went for my safc tune =)
![](http://i19.photobucket.com/albums/b155/joe-wolf/DSC00450.jpg)
also the usdm gte is better because the turbos are not ceramic...
#49
The only thing is if you want more then ~300whp you need to use a TT headgasket to lower the comp to run higher boost safely on pump gas..
i think the average being about 17lbs of boost on a tt hg ..but theres other ways as well...you can stay stock comp and use water or meth injector or use e85 if its common in your area....anything over 300whp in a ge will need some upgrading like injectors hg tranny..on a gte anything over probably 400whp and you'll need to start upgrading the same things minus the HG
