SC- 1st Gen (1992-2000)
OEM Power Steering Hose for $660 or Braided Stainless Steel for $65
Old 02-07-11, 06:50 PM
  #31
VanillaSC
VanillaSC's Avatar
Any one know exactly why they are listed as 2 separate parts? I thought the pressure hose was just one piece?
Old 02-07-11, 07:04 PM
  #32
SEXC
SEXC's Avatar
Would you happen to know what's the inside diameter. I wonder if I could make myself one at work since I have a roll of 3,000+ psi hydraulic hose laying around.
Old 02-07-11, 10:57 PM
  #33
FiSta
FiSta's Avatar
Originally Posted by Luxor
I'm curious, this hose gets rid of the two sensors located at each end, does it affect steering at low or high speeds?
have mine on roughly over a year now with no real issues. only thing is if you don't use don't use those sensors, your idle will drop. like mine goes a tick below 1k when warm and when i turn the steering wheel it will drop some more.
another thing i notice is after installing this hose, it whines when i turn at low speeds. any thoughts on that?
Old 02-10-11, 04:06 PM
  #34
VanillaSC
VanillaSC's Avatar
Update:
I ordered the edelmann hoses and dropped them off at the shop where my SC is at, compared it to the old hoses and the fittings match. Just to be safe I ordered the top hose that comes off the resevoir from the local lexus dealer for $28. And I'm also having the TM Engineering steering rack bushings put on (I ordered them a few months ago and never put them on). So I should have my car back by beginning of next week with basically all new power steering.
Old 02-10-11, 05:50 PM
  #35
Gimpster
Gimpster's Avatar
Good to know! Thats a reasonable price for those two hoses.
Originally Posted by VanillaSC
Update:
Old 02-16-11, 09:36 AM
  #36
jer_con
jer_con's Avatar
Hey Vanilla....
I'm debating on ordering these hoses myself and was hoping you might have some feedback soon from the installation. Thanks!
Update:
Old 02-16-11, 11:36 AM
  #37
cartmill
cartmill's Avatar
guys,
just FYI:
1. the driftmotion stainless hose does not have the vacuum port on it --the thing with two vacuum lines coming off it. this port creates an air bypass (metered 'vacuum leak') to raise the idle when the power steering pressure goes up.
at a ~$500 cost savings (wow!) most of us are going to say "who cares," but you should all know your idle will dip down considerably when you turn the steering wheel.
2. there is a power steering pressure sensor at the bottom of the SC300 line that is absent on the aftermarket units as well. i am not sure what the purpose of this sensor is off the top of my head. anyone feel free to check it out in the FSM
can someone post pics of the edelmann hose? i couldnt find this hose in edelmann's online catalog (application lookup) or on Gates' website.
Old 02-16-11, 12:10 PM
  #38
jer_con
jer_con's Avatar
Look on RockAuto.com. The Eldemenn site does not provide a pic but they are there. I took the vacuum ports off of my hose when I changed the rack and welded the adapter closed. My SC idle doesn't change much when I turn the wheel.
Originally Posted by cartmill
guys,
just FYI:
Old 02-16-11, 05:57 PM
  #39
6SOARER
6SOARER's Avatar
I just picked up my hose for $45 at G&J who I believe makes these hoses for DM. Install was easy, took me 30 mins but hadnt had a chance to test it out cause the front main seal is leaking again.
Old 02-16-11, 06:05 PM
  #40
MDSC
MDSC's Avatar
so about to order the Supra TT line, anyone tried it? as the oP said he heard that it works, its only like 50bucks so i guess i'll give it a try when i replace my p/s rack.
Old 02-28-11, 09:27 AM
  #41
jer_con
jer_con's Avatar
I ordered the braided SC400 High Pressure PS line from Drifmotion. It looks just fine to me; hoping to get some time to install it this week.
Old 02-28-11, 09:41 AM
  #42
outlaw0209
outlaw0209's Avatar
Going to order one this week. Mine is leaking from this past drift event.
The hose will work. Those sensors are not mandatory, or else they wouldn't sell it and people wouldn't run them. I'd rather pay 65 and sacrifice my idle for a hose that probably will never leak, rather than a 300+ dollar stock hose which can later leak as well.
Then again I drift. So more than likely a stock hose will definitely leak again. Some of you don't so it probably won't.
Old 02-28-11, 11:16 AM
  #43
VanillaSC
VanillaSC's Avatar
Originally Posted by jer_con
Hey Vanilla....
The edelmann hoses worked just fine. I had the hoses, pump, and vacuum switch replaced along with daizen steering rack bushings and my steering is as good as new now.
Old 03-03-11, 08:25 PM
  #44
khailon
khailon's Avatar
anyone tried to install the Supra TT line onto sc300?
Old 03-04-11, 02:15 AM
  #45
KahnBB6
KahnBB6's Avatar
Received 1,236 Likes on 864 Posts
I'd like to know this too. I'm going to replacing my high pressure hose soon and I'd like to avoid buying the Lexus part.
Quick Reply: OEM Power Steering Hose for $660 or Braided Stainless Steel for $65
