SC- 1st Gen (1992-2000)
First steps towards sc400 R154 conversion
Old 02-05-11, 06:58 PM
fleishelja
fleishelja's Avatar
Default First steps towards sc400 R154 conversion
So I got the bell housing, flywheel, adapter plate, hydraulic tob, tob "mount?" sc300 clutch pedal assembly and master cylinder for 5 hundys. The flywheel is a modified 01 tundra v6 flywheel. fitted with a spacer and sc400 ring gear. the clutch and pressure plate are off the same car 01 tundra v6. it turns it into a push instead of pull type as you all have obviously noticed. now I just need the trans, and a driveshaft. any ideas on which driveshaft will fit?
Old 02-05-11, 07:00 PM
willhickey
willhickey's Avatar
whats the bell housing off of ? so those tundra parts will work? i have a mk3 supra trans and driveshaft (r154) im trying to find out the same thing, customs the only thing i can think of
Old 02-05-11, 07:01 PM
willhickey
willhickey's Avatar
dadam you got a steal all that for 500?
Old 02-05-11, 07:05 PM
fleishelja
fleishelja's Avatar
tundra stuff will work. the guy I got the stuff from had an aluminum spacer made and cryo'ed the flywheel then heated the ring gear and spacer and compression fit it all together. the problem is the starter wont reach the far enough so you have to make the ring gear sit about 2 inches farther back
edit: just noticed another question. the bellhousing is a sc400 bellhousing
Old 02-05-11, 07:30 PM
willhickey
willhickey's Avatar
and that bolted right up or youlle have to modify it? dang you still got a steal!!
Old 02-05-11, 07:31 PM
fleishelja
fleishelja's Avatar
all this will bolt up. flywheel is already modified. good thing tax time is here, I'm gonna need it for a r154 lol.
Old 02-05-11, 10:03 PM
xxtoobsxx
xxtoobsxx's Avatar
quantum auto makes a flywheel and clutch combo for the sc400.
Old 02-06-11, 09:39 AM
ucmysc400
ucmysc400's Avatar
^+1
Old 02-06-11, 11:07 AM
Emilio253
Emilio253's Avatar
Step by step PLease!? lol I am going to do this soon and I need as much info as possible! thanks !
Old 02-06-11, 01:17 PM
scENFORCER
scENFORCER's Avatar
I'm considering this more and more for my '99, which should be the same procedure as this since yours is a '97 and OBD2, correct?
What are you going to do about the CEL?
From what I've read a 10K resistor takes care of that. A few people have done the 98+ OBD2 manual swap in 300's, but no one whose actually done the swap has confirmed that..
Old 02-06-11, 04:41 PM
xxtoobsxx
xxtoobsxx's Avatar
Man yall are lighting a fire under my **** with all this talk of manual swaps! I have everything to do the swap but the flywheel and clutch! But...i need to replace my wheel bearing and front LCA's first, sad day i know
Old 02-06-11, 06:25 PM
willhickey
willhickey's Avatar
so what all do you have then? i have the mk3 r154 trans and driveshaft could someone give me part numbers etc. for everything else i need? and should i buy the bellhousing adapter or just buy the drawings and take it to a local machinist? thanks for any and all advice/ideas
Old 02-06-11, 07:15 PM
iridebmx
iridebmx's Avatar
may i have a joy ride? i live in GA too!!! haha jjkjk nice to see that in the next few years there will be lots of manual sc400's
Old 02-06-11, 08:42 PM
chnk
chnk's Avatar
manual sc400 in ga? nice cant wait to see this car its so clean
Old 02-06-11, 08:55 PM
Gimpster
Gimpster's Avatar
No doubt.
For what some people want for an R154 it would be almost cheaper/as cheap to buy a 1JZ+R154 swap off ebay and sell the 1JZ
Quick Reply: First steps towards sc400 R154 conversion
