Shift solenoid from sc3 auto fit in Sc4 tranny?
Im getting an sc400 ready to sell, but currently its shifting is acting up, and has been for aprox. 1500-2000 miles. I saw auto tranny fluid running down the driveway 2 days ago, and since then there's been a significant change in the tranny issues. Flashing o/d light, and at a red light the car falls out of, and kicks back into gear several times before it turns green. Seems itsjust super low on fluid.
I pretty much assume the solenoids are bad, causing the o/d flashing. The pan is leaking, so while I could probably get away with gray liquid gasket, a new gasket for the pan would be best along with some gray stuff. I have a spare sc300 tranny, and im curious if the shift solenoids will be a direct swap, or if I should by the non-direct replacements for my sc4 tranny that need shims and bracket modding to bolt in and be seated correctly? I just want to have the car shift decent again so I can sell it. Suggestions appreciated!!!
I just made a posting in the other thread you were in. The shift solenoids help the car change gears by diverting the flow of fluid different directions (I assume you already know this
If the car is falling out of gear I would fill it back up with fluid and see if it fixes the problem before you dive in to change solenoids when it could be a deeper issue.
ON my 4runner when the solenoids were failing my symptoms were that it would not start out in 1st gear. With a solenoid failed the car would start in 3rd gear. So no power. O/D light flashing, than the solenoid would click and off we would go. Sometimes on the freeway the O/D light would just start flashing.
YOu should pull the codes and see if you have a failed shift solenoid code in. I never had the car just fall in and out of gear.
Do some research but I bought my solenoids from here. It lists as being compatible with the A340E, even though Lexus is not on the list. Its a bit more than that other kit, but the brackets are already tacked on the solenoids. So no shims or modifying the bracket.
Good luck.
http://www.electricaladvantage.net/a...olenoid-1.aspx
Good luck.
AndySC400
Performance & Maintenance
01-13-04 02:44 PM
