92-94 sc corner light to foglight idea
I was thinking the other day about these things.
What if you opened up the light housing and covered the inner casing with mylar tape, than built a little curve so the beam pattern points more straight. Anyone think this would work?
Picture of example:
(imagine looking at it from the top)
the gray area would be tape and the red would be something you put in to avoid the sideways beam pattern. i also forgot to draw that there would be mylar tape covering the red so it reflects backwards
Picture of example:
![](http://i19.photobucket.com/albums/b155/joe-wolf/stupididea.jpg)
Not a bad idea, but I have a better one:
http://piaa.com/Lamps/Lamp-pages/004xt.html
retrofit...those are almost identical to what I placed inside my factory cornering lamp housings, with a set of HID's, and when they are off, you cant even tell.
wouldnt that still point sideways? im wanting to avoid some the sideways beam pattern whenever i do decide to wire the corner lights up to my running lights.
Just a couple of reference pics for you:
Fitting the lamp inside the housing
![](http://i45.tinypic.com/2wolrua.jpg)
Mounted and on, before adjustment and the HID's till warming up
![](http://i46.tinypic.com/2a82hl3.jpg)
Horrible Cell phone pic of both sides on, with the lenses and complete, but the lights were adjusted more after
![](http://i44.tinypic.com/15hiczq.jpg)
During the day with the lights off:
![](http://i43.tinypic.com/x5vx54.jpg)
Faux fogs will simply not yield the same results, with reflective tape or not. The PIAA styled lights I used take a 962 (IIRC) style bulb, and fit perfectly in the housings. Took about 2 hours to fit both sides and that included making the brackets.
It costs more than the faux fog, but the results are far greater, and actually serve a purpose.
