ground, tps? I'm stumped
#47
Yea, I just couldn't get it to start yesterday.... and when it did, it ran like *****.
I'm gunna try to get it to run right and then pull the knock sensors out the block and keep them plugged in and taped to the harness so they can't detect knock and see what happens
#49
Yea, it's just so frustrating walking outside every day and seeing my car and not being able to drive it... it sucks, it's been over a year and I've started multiple threads and no one has ever quite figured it out.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#54
Very good idea! I think that's something that needs to be done, I realized today that the only thing i havent really checked was the injectors and mk4 resistors...
how would i go about doing testing those with my multimeter?
#55
ok so after pulling my harness apart and inspecting it, I noticed most of the very important connectors were very brittle and covered in oil....
I noticed that my connector for the coolant temp sensor was covered in grease and oil and where the wire meets the connector, wire on both sides were exposed and it looked like on one side, only 25% of the copper was making contact with the connector, the rest of the copper wires inside the one little wire were broken off... I wonder if this could be my problem....
So i researched symptoms of a bad coolant temperature sensor and BAM, it described all of my problems.
So tomorrow I'm going to go to the toyota dealership and buy a bunch of connectors, I'm going to replace any questionable connector and go from there..
I'm hoping what happened was that the bad connection to the coolant temp sensor was causing all of this....
#57
Hey, what exhaust you got on it? Factory, or newer? These symptoms sounds just like a clogged exhaust not allowing the fumes to exit and just backing up the engine, causing it to stall. Hope you have luck with the connectors, but if not, give it a check.
#58
Still waiting on my connectors, but that is a really good idea, maybe from all the tuning and running rich it clogged my mufflers?
I have full stainless 3" split to two 2.5" with two canister style mufflers, not fart can style.... so maybe?
