Does Anyone Know Of A Cheap And Easy Way...
#31
This is the same guy that made this post...
"you guys are a bunch of pansies. I've hit my limiter multiple times with studded snow tires and once Ive even steered the car with my knee @ 150 while I lit up a cigarette. I can't wait to get that limiter removed (and install a 5 speed) to see what it'll actually do."
Matt, I'm sorry that you feel the responses you've been getting aren't direct or credible, however you would do well to consider how you are asking your questions. You're saying that your turboed 1uz is struggling against an acura TSX. That right there is an extremely hard pill for any of us to swallow here.
To blow off some steam earlier today (because of a stupid girl not CL) I pulled apart my entire throttle body, cleaned the **** out of it and went for a drive and I think my sh##y mutant manifold is starting to fail, which is probably whats causing me to lose boost, but I still think 2nd gear is too tall and I would love to test my theory of raising the rev limiter to 7000 or 7500 rpm. I know doing a 5spd swap would be more ideal for what Im trying to accomplish but Ive been having a hard time finding a decent r154 or even w58 and like I said, I just blew way to much $ on other areas of the car but youll all have to wait 1 more week before you get to see it.
#32
Dude if you want info on sc300 or 400 in colorado find FrankDMS. or go to the www.triplecrowndrift.com site. i think his email is frank@denvermotorsports.com
PS quit you BS crying stuff. and if your getting beat by a TSX something must be jacked up
#35
#38
Im not questioning your logic or being sarcastic I just really dont know alot about turbos and I like to learn wherever I can.
And im also assuming the bigger the turbo the longer it takes to spool?
Spooling=the turbo giving power to the engine?
Thanks in advance
#39
why would a v8 spool the turbo faster than say a v6?
Thanks in advance
Thanks in advance
With that out of the way, quick and dirty physics lesson for you
Force = Mass * Acceleration.
So with that in mind, if the acceleration of an object stays constant but it's mass increases, force will increase right?
A 3.0 i6 will move less mass of exhaust vs a 4.0 v8 at the same given RPMs, therefore the exhaust coming out of the 4.0 will have a greater force on the exhaust wheel of the turbo.
Now we go back to the initial formula, As the force on the exhaust wheel increases and mass stays the same, acceleration will increase. And we now have our faster spool time
#40
We'll he's going with the generality that v8s are typically larger displacement which tends to hold true, as v8 under 4.0 liters are fairly uncommon and 6 cylinder engines over 4.0 liters are uncommon as well
With that out of the way, quick and dirty physics lesson for you![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Now we go back to the initial formula, As the force on the exhaust wheel increases and mass stays the same, acceleration will increase. And we now have our faster spool time![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
thanks for explaining thaqt .
to show you how limited my knowledge of turbos are, I didnt realize till now that they are powered by the exhaust of the car its attached to.
interesting
#41
Either no turbo or one of the coil packs is unplugged...or something. My W58'ed '93 ran mid to high 14's (time-slip verified) at sea level with everything else stock and an unplugged maf because my ecu was old and probably had half leaking capacitors or something.
Regardless, if you really were boosted you should go standalone and for under $600 you can build your own Megasquirt 3/X and install it. You would also need a wide-band which you should already have if boosted anyways. I got mine dialed in better than the factory tune [in most areas] within a week.
I would love to see a dyno of a stock 1uz revving to 9k lol. It would be a perfect parabola!
