SC- 1st Gen (1992-2000)
sc400 broken antenna
Old 02-24-11, 12:27 AM
habsa56
habsa56's Avatar
Default sc400 broken antenna
The OEM antenna on my car is broken, And im looking to buy a replacement one... But I dont want another OEM antenna... Does anyone know where I can get a replacement antenna that looks good and is easy to install?
Old 02-24-11, 12:50 AM
CrazySC300
CrazySC300's Avatar
I've read around these forums for the "Honda S2000 replacement".
Old 02-24-11, 06:21 AM
Tabaka
Tabaka's Avatar
S2000 replacement is the way to go. $10-20 on ebay.
Old 02-24-11, 07:06 AM
xspsi6
xspsi6's Avatar
I am curious about this as well, Do you need a whole antenna from the s2k? I assume we are not talking about just the mast but rather everything from an s2k retrofitted to an sc3/4?
Old 02-24-11, 07:10 AM
BiGEZ
BiGEZ's Avatar
As mentioned above the Honda S2000 is a nice fit but to get the base is about $100 even on eBay. The antenna mast is cheap and plentiful.
I ordered a Mark IV Supra kit with the amplified unit from loCustom.com for $46.00 shipped. Should have it in a few days and see how well it fits and works.
Will post some pics when I get installed.
Old 02-24-11, 07:14 AM
Tabaka
Tabaka's Avatar
doh, forgot about the base. You will need that too. Keep your eye out on the bay and you'll find one for a good price.
Old 02-24-11, 07:32 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I still would rather have the factory one. JMO. Good luck with your choice.
Old 02-24-11, 06:23 PM
habsa56
habsa56's Avatar
Thanks for the help guys... But I wasnt looking to spend over $100 on a replacment antenna... I think my antenna motor is broken too because it doesnt go up or down the antenna jus stays half way up... I still get good reception though... I was just looking to remove the OEM antenna and install a small aftermarket one... I found a nice small antenna on ebay for about 20 bucks but not sure if it would work... heres the link...
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
Old 02-24-11, 06:27 PM
xspsi6
xspsi6's Avatar
That's just the mast so you still need the base as mentioned above...
Old 02-24-11, 06:51 PM
abounly
abounly's Avatar
Hmm do you really need a antenna? I unplug mine cause it looks ugly and the signal is still the same to me
Old 02-24-11, 06:57 PM
habsa56
habsa56's Avatar
I could remove the antenna... But then wouldnt there be a hole where the antenna was??? And where can I a find a base to the antenna??
SC YAA
SC YAA's Avatar
I broke mine off to last summer and ever since the signal is s#@t! It goes in and out and i need to replace mine soon. Is there a diy on how to change just the mast?
Old 02-24-11, 10:21 PM
kaban1993
kaban1993's Avatar
I would go factory because it is 15 dollars on ebay
Old 02-24-11, 10:23 PM
kaban1993
kaban1993's Avatar
I think you have to go through the trunk, but I was also told that a speciall screwdriver is needed to get the bottom part of the mast off.
Old 02-24-11, 10:32 PM
BunthaKev
BunthaKev's Avatar
you can use a pair of channel lock pliers to remove them. It's like $10 for the whole universal antena kit on rockauto.com. I bought three of them and will use them on my ES300, already installed on my integra and was going to use it on my ls400 but I found an internal antena and will do the body work to cover the hole. I hate power antena's. All the noise they make LOL!! So I removed thw whole power unit and replaced it with this bare bones antena and shaved 3lbs. I also blieve you can use this base and the s2k antena. I beleive the diffrence is the mast is shorter on the s2k by a few inches.
Quick Reply: sc400 broken antenna
