SC- 1st Gen (1992-2000)
what is the best turbo to get for right now power?
Old 02-24-11 | 05:37 PM
moto696's Avatar
moto696
Default what is the best turbo to get for right now power?
i have a 93 sc w/ a 1jzgte twin turbo out of a 95 supra. has a inter cooler bov and a air intake. i am going to use this car for drift and scca events. i searched on the threads for info but still just have no idea. i am looking for a set up (single or twin) for the best right now power for drifting and track days (road coarse). and because i have a twin set up and if i go to a single i would need a new manifold right? sorry still learning cars. so what is the best turbo for what i am going to do and why? thanx
Old 02-24-11 | 05:40 PM
FatBrian81's Avatar
FatBrian81
Are you sure you have a 1jz, the 95 Supra should have a 2jz-gte.
Old 02-24-11 | 05:44 PM
moto696's Avatar
moto696
i did not do the swap the old owner did and i have the paper work here and it says it was imported for japanout of a 95 supra w 57k miles? imight go open the hood to look for the 1jz or 2jz badge. do you know what side of the block it is on?
Old 02-24-11 | 05:45 PM
moto696's Avatar
moto696
and where in nc are you i will be moving to charlotte in march
Old 02-24-11 | 05:56 PM
FatBrian81's Avatar
FatBrian81
I live just outside of Charlotte. The Mark IV Supra (93-02) only came with a 2jz 3.0 I6, either naturally aspirated or twin turbo. If you have a 1jz its not out of a 95 Supra.
Old 02-24-11 | 06:05 PM
EastSC3's Avatar
EastSC3
Yeah you do need a new manifold, and how much HP you want to achieve?
Go onto Supra Forums and Club Na-T, they have alot of info on Single Setups
Old 02-24-11 | 06:16 PM
turbodremz's Avatar
turbodremz
just post a picture of said engine. if a 1jz came out of a 95 supra, unless its built, someone took a step backwards imo...
keyword to stay on topic though: 60-1
Old 02-24-11 | 06:25 PM
moto696's Avatar
moto696
it is to dark now and it is -13 out. so i can tomarrow. but does it matter (just for tonight) what motor is in the car? and i would like to get 300 to 375 to the wheels.
Old 02-24-11 | 06:38 PM
DKJZZ30's Avatar
DKJZZ30
if all you want is 300-375 to the wheels just use the stock turbos. nothing will spool faster than those. you could get them ported and steel wheeled and they will be good to go.
Old 02-24-11 | 06:42 PM
moto696's Avatar
moto696
thats sounds good should i have a bigger target number? and can i get 350 torque from them? hp is nothing without torgue for what i am doing
Old 02-24-11 | 06:51 PM
DKJZZ30's Avatar
DKJZZ30
you dont have to have a bigger target number. if your looking for quick response nothing will spool as fast as the stock turbos so that may be something to look at. you should find out which motor you have first since the 2jz turbos are better than the 1jz turbos
Old 02-24-11 | 06:54 PM
SC51's Avatar
SC51
FatBrian81 I live just outside of Charlotte. The Mark IV Supra (93-02) only came with a 2jz 3.0 I6, either naturally aspirated or twin turbo. If you have a 1jz its not out of a 95 Supra.
Good info I bet alot of people didn't know they sold the JDM Supra up untill 02 in Japan
As far as your power goals/spool time you should stick with your twin setup if not you can get a manifold and like a 60-1 Snail.
Old 02-24-11 | 07:02 PM
moto696's Avatar
moto696
this is good info thanx and i will look at motor. i do have some money to spend on the car but dont want to spend $5000 on just the motor so i like using the turbo's i have. should i look into a piggy back ecu system for tuning and will that give me more useable power
Old 02-24-11 | 07:03 PM
tig_tech's Avatar
tig_tech
Left side of block under intake manifold.
Old 02-24-11 | 07:05 PM
moto696's Avatar
moto696
thanks tig
