SC- 1st Gen (1992-2000)
Aem ems gte to ge
Old 02-27-11, 09:17 PM
broda805
broda805's Avatar
Default Aem ems gte to ge
I've been searching a couple days now on how to re wire the aem ems for the gte into my sc with the stock ge I hear you have to swap a few wires or so but all the threads I've found so far are left open ended without a definate answer but it has been done.
Any one know how to or a link to a thread on how to do it, it would be greatly appreciated.
the reason being is that I can get a used tt ems alot cheaper n more common then the na version, don't have the funds for a new v2 made for the na at 1800$ getting a used tt ems for around 850 and spending some hours rewiring n saving some money it's what I'm going for
Old 02-28-11, 07:48 AM
good2go
good2go's Avatar
Have you looked in the AEM forum?
Old 02-28-11, 09:07 AM
scviolence
scviolence's Avatar
dude if u figure this out lemme know. i been searching for the same thing and its just like you said everything is left open ended no one says ooh yeah it worked or hey ya need to do this or that...grrr
Old 02-28-11, 11:32 AM
broda805
broda805's Avatar
i THINK if we can find a ecu pinout of a GTE and GE and switch around whats different and add the map sensor...... it should work... but i'll keep on searching in the meantime
Old 02-28-11, 04:41 PM
99SC42
99SC42's Avatar
It's easy i will send you the like tomorrow.
You just use the maf wire to rewire you ait sensor and map sensor.I can't remember off top off my head.
I am not sure about V2 but if you are talking about V1 i can help you with that.
Old 02-28-11, 06:16 PM
lfrers
lfrers's Avatar
I know your asking about the V1 but just for info I was told when I bought my V2 that to switch between GE & GTE it's just a jumper inside the unit.
Old 02-28-11, 06:48 PM
Matador
Matador's Avatar
Wouldnt a jumper harness work for this?
Old 02-28-11, 06:50 PM
99SC42
99SC42's Avatar
It's a simple task no jumper harness is needed the TT and GE as long as it's not 98 they both use the same still ECU connectors.
Old 02-28-11, 07:36 PM
broda805
broda805's Avatar
yeah v1 obd1 yeah if you would when you got time shoot me a link or pm me
Old 03-01-11, 04:10 AM
lexforlife
lexforlife's Avatar
dont forget the repinning for a/c request as well
Old 03-01-11, 05:52 AM
Biggu
Biggu's Avatar
it will work my buddy has a aem v2 on his GE that was made for a GTE
Old 03-02-11, 04:37 AM
99SC42
99SC42's Avatar
Here you go sir USE the one that say 30-1101 that's what you need.
File Type: pdf
File Type: pdf
Old 03-02-11, 07:17 AM
nivek5sfe
nivek5sfe's Avatar
http://www.supraforums.com/forum/sho...9-TT-AEM-on-NA
that thread could help you out also
Old 03-02-11, 02:15 PM
broda805
broda805's Avatar
Old 03-02-11, 02:19 PM
99SC42
99SC42's Avatar
kOOL let us know how it goes... i like wiring an sC or Supra to AEM EMS since and if you run into issues it will help you diagnose the problem atleast it help me a couple times.
Quick Reply: Aem ems gte to ge
