SC- 1st Gen (1992-2000)
Corning/Fog light HID retro fit idea
Old 03-02-11, 09:23 PM
NEbiker10
NEbiker10's Avatar
Default Corning/Fog light HID retro fit idea
I have a spare set of 9006 HID. I figure I might as well use them in my corning lights. I wanted to find out how I could retro fit them. I came up with a few ideas but this one seem the most solid. Here we go. Junkyard is a must.
Go to the junkyard and find a headlight/fog that is 9006 and has a similar curve to it.
Drill out the top hole with this.
Do the Same on our corning/fog light. make sure its the same angled cut. Then take the 9006 one and secure it somehow to our light. I figured Hot Glue or epoxy. Maybe even heating up both plastics with a blow torch and fusing then together. This way you would have a perfect 9006 retro fit.
Old 03-02-11, 10:02 PM
Klaus
Klaus's Avatar
Old 03-02-11, 10:05 PM
ShiftyD2k
ShiftyD2k's Avatar
i already mod my car cornerlight hid and it's look weird to me so i put back jdm yellow bulb better...
Old 03-02-11, 10:10 PM
iridebmx
iridebmx's Avatar
heh?.... i dont get the concept
Old 03-02-11, 10:29 PM
aznxenon
aznxenon's Avatar
Do it! Except I'm currently under the influence so I'm not exactly sure what you're actual plan is. Regardless, do first, think later.
Old 03-02-11, 10:36 PM
turbodremz
turbodremz's Avatar
Already did a retro fit on the factory cornering laps with fogs, but I did it the "right way" and actually stuffed a fog light assembly into the housings.
Old 03-02-11, 10:50 PM
NEbiker10
NEbiker10's Avatar
Almost like this
Old 03-02-11, 11:56 PM
Bender25
Bender25's Avatar
Do what I did and just retrofit an ES300 foglight into the cornering light housing
Old 03-03-11, 08:26 AM
skirts
skirts's Avatar
Do you have a diy or pics?
Old 03-03-11, 09:15 AM
Klaus
Klaus's Avatar
Why not pick up a set of 95 fogs?
Old 03-03-11, 09:39 AM
turbodremz
turbodremz's Avatar
^^95 fogs dont fit the pre-95 bumpers.
Old 03-03-11, 10:10 AM
Bender25
Bender25's Avatar
here it is on-
And here you can see the projector in the stock housing-
Old 03-03-11, 11:26 AM
kyddo112
kyddo112's Avatar
here it is on-
is aimed at an angle or straight ahead?
Old 03-03-11, 11:58 AM
nivek5sfe
nivek5sfe's Avatar
sounds like a plan. go for it. we need more options for these lights
i was just going to use a hole saw like that on the light housing , mount an aftermarket foglight, then slide the light housing over the fog light.
Old 03-03-11, 12:09 PM
Klaus
Klaus's Avatar
Quick Reply: Corning/Fog light HID retro fit idea
