SC- 1st Gen (1992-2000)
Supra vs. Aristo 2jzgte installation...
Old 03-04-11, 02:19 PM
  #31
99SC42
99SC42's Avatar
^ welcome to the forum, please edit your post from his thread it's not fair for him.
You can start your own thread and we will steer you in the right right direction.
Old 03-04-11, 06:12 PM
  #32
HiPSI
HiPSI's Avatar
Originally Posted by 4thHorsemn
These are my plans:
2jzgte w/ v160 both from supra
Carbonetics clutch
Hks 272 cams
Titan cam gears
Haltech ps 2000
Custom intake and exhaust manifolds
4" exhaust
pt7076 turbo from precision
Injector dynamic id1000 injectors
Precision intercooler
Harness by tweak
Supra tt rear end and drivers side axle
2 Bosch pumps inline
Aeromotive fpr
Mack boost solenoid
5 bar map sensor
I'm leaving a few things out but 15k later I should be in the 850 hp range.....
That is a costly but solid build plan, and really the only route to the hp goals that you have.
Old 03-04-11, 06:26 PM
  #33
RX7 RAGE
RX7 RAGE's Avatar
I didn't have to replace my tunnel in my 92 sc300 for the v160 swap as well.
Go big or go home!
Old 03-04-11, 06:53 PM
  #34
account2x
account2x's Avatar
These are my plans:
Carbonetics clutch
Hks 272 cams
Titan cam gears
Haltech ps 2000
4" exhaust
Harness by tweak
Aeromotive fpr
Mack boost solenoid
5 bar map sensor
That is what I call a build.
Old 03-04-11, 08:18 PM
  #35
4thHorsemn
4thHorsemn's Avatar
Oh yeah, and a v160 crossmember 
Old 03-06-11, 05:32 PM
  #36
jh4ka7
jh4ka7's Avatar
Originally Posted by HiPSI
It's threads like these that confuse the hell out of new members trying to figure out which route to take.
I disagree. I actually think its threads like this and the other "1j vs 2j" thread that people learn a lot from. I'm a noob when it comes to build and stuff like that, so as proponents of a particular setup give their reasoning behind their choice the other side weighs in - shedding real light on that matter for the rest of us.
I've also learned a lot fom quickgs300, that guy really knows his stuff and he never goes cheap/shortcuts that'll end up costing me more.
he did my tb/wp and a whole bunch of other stuff for me. cool cat!
Old 03-06-11, 07:27 PM
  #37
account2x
account2x's Avatar
Originally Posted by suislide
Now it's NA-T vs 1JZ vs Supra 2JZ vs Aristo 2JZ
No Sir. The 1JZ and the 2JZ came in many different chassis. In order to accomplish this versatility Toyota has to modify the engines. Some engines have mechanical fans, some engines have front-sump oil pans, some have shorter brackets, etc.
In order for the block to fit your chassis it needs to have the appropriate accessories.
A Chaser 1JZ is front-sump. A Soarer 1JZ is rear-sump.
If you bought a Chaser 1JZ you need to change the oil pan.
Aristo 2JZ vs. Supra 2JZ is the exact same-way.
Old 03-07-11, 07:38 AM
  #38
99SC42
99SC42's Avatar
I asked the Op because he PMed me a couple months ago, because at first he was just buying a V160 not the whole swap and maybe na-T,please don't jump to conclusion.
Old 03-07-11, 07:44 AM
  #39
suislide
suislide's Avatar
Great to learn something new. Thank you Sir.
Now back to NA-T vs 1JZ Soarer vs 2JZ Supra for me
Old 03-07-11, 11:35 AM
  #40
4thHorsemn
4thHorsemn's Avatar
I never wanted na-t due to overall cost of the power numbers I'm trying to reach, I might as well start off with the RIGHT foundation. GTE all the way. I won't start my build thread until I have 90% of my parts in. I'll keep everyone posted!
Old 08-20-13, 07:15 PM
  #41
623lexus
623lexus's Avatar
Originally Posted by Cleanshots
i say 6spd is overrated and i dont like it. go aristo and r154. fuel pump go mk4 tt, you need rear sump. you need ur ge mounts and need to be modded for clearance for the gte, get new plugs, ngk bkr7eix, do mk4tt water pump (whole pump), u need intercooler your gonna geed mk3turbo front part of drive shaft for the r154, i suggest a beefy clutch, upgrade the radiator to alum and better cap, new thermostat, new vac lines, exhaust needs to be redone, r154 shifter handle extension or actual housing extension both do the same thing one is waste of time and money. timing belt is recommended, and i say go electric rad fan as well DONT FORGET 12V fuel pump mod.
and search iv covered this 1000 times.
At the risk of being a noob....I have an 01 is300 automatic. ...I was told an aristo swap would be better to do...as I would not have do a tranny conversion...I was wondering what the differences are between a supra 2jz-gte and an aristo...which has stronger internals...I really want a standard tranny...how much work would a tranny conversion entail....any info will help...thx
Old 08-22-13, 10:00 PM
  #42
Cleanshots
Cleanshots's Avatar
u will blow up ur stock trans... r154 is needed if you play your cards right probbaly about 1100-1700 for complete r154 conversion.
SC300TT!
Performance & Maintenance
84
01-23-13 08:37 PM
cavette
05-03-09 07:33 PM
sunrisetrd
11-20-08 08:57 PM
DCMango
02-16-06 07:02 PM
jdmjunk
GS - 1st Gen (1993-1997)
12-01-05 10:11 AM
Quick Reply: Supra vs. Aristo 2jzgte installation...
