Help! Need advise on short shifter!
I had a TRD MK4 quick shift kit on my 95 SC300
Yeah a buddy of mine that welds just did one for my MK3 Supra..
lol look how tall the factory shifter is in this car, it's nuts..
![](http://i83.photobucket.com/albums/j309/erikbalanza/Supra/DSC00396.jpg)
cut off about 5 inches, and now it looks normal at least. welded it grinded it down and sanded it..
![](http://i83.photobucket.com/albums/j309/erikbalanza/Supra/DSC00526.jpg)
on the pre 95 SC's you can remove the shifter from just the top like on my supra.
as far as vibration goes, you will probably get that with any short shifter, I had that expensive TRD short shifter on my SC and it vibrated so bad i thought bout going back to stock, i eventually got ghetto and wrapped the shifter in dynamat and it helped alot
I'm cutting some out of the top of mine and adding it to the bottom to make my own. Can't see spending so much $ when you can make the same damn thing as they're selling. Running a weighted **** that should help with any extra vibration.
I finally found a shifter that fits my 93' SC 5spd tranny! Thanks everyone for all this important information and advise! Now my project should be on the road in no time
http://www.twmperformance.com/short-shifter.html
GO MATH AND READING! booyah.
just to clarify, an actual short shifter shortens the throws between shifts, not necessarily the height of the shifter. It all depends where it pivots, and i think that they just move where it pivots.
Maybe you should try that math and reading thing again... I said take from the top (above the pivot) and add to the bottom (below the pivot... changes the pivot. Look at a short throw shifter and its the same thing. Awww not so smart now are ya? Booyah lol. Try working on cars and actually making **** instead of looking at what you can buy and what others feed you and get back to me.
The last part was mainly sarcasm. If you want to take the discussion further, just pm me i dont want to pollute this thread.
Sorry on the hostility lol. I do know what I'm talking about here though.
Just to let others know you can make the same shifter that people are spending hundreds on for just a few cuts and a few welds.
The stick right above and right below the pivot is the same diameter. Cut out a section from the top, make a cut in the bottom, weld the piece you cut out of the top into the bottom and weld the top back together and viola short throw shifter.
Look at your shifter and look an a picture of an aftermarket shifter and you'll see that's all it is. Ours are just simple metal sticks, no base or anything like on a vette or f-body etc.
scfou
Performance & Maintenance
45
02-12-16 05:31 PM
