Replaced the brakes and new rims
i agree with everyone else. you should look into a wide body unless you are going to do a serious pull and lots of negative camber. im looking forward to see what you do though, it should look awesome
Madd Negative camber is prob the worst thing you could do.
Yup, toe (can be) way worse than camber.
You can remount your left and right side tires with camber wear to get the full life out of your tires.
I have the same Irotors and SS lines with DOT5.1 Fluid in my brakes. No issues at all with warping, and I am not nice with my brakes lol.
Thats good to hear,because the 2jzgte swap should be in the car soon
These will no fit with the stock panels at all unless you are down with running extreme camber. If you really want to look into some front fenders from either Vertex or Origin. As far as the rears send me a PM. I can put you in the right direction for some rear overfenders. Cheapest and easiest way to go widebody. I know these will not fit under stock modded panels. I'll be running a 18x9.5 -7 and I have 25mm front fenders.
