1995 Fog Light Covers?
I have been in search for fog light cover/film for my 95' sc3. Unfortunately I can only find them for the 97' up fogs. Am I going to have retro fit the 97's or is there someone who actually sells them? Reason for trying to find some is because I recently installed 3k HID's in the fogs and They are not the deep yellow I had hoped for. They are more of a lime green/yellow. Or maybe if I were to color the inside of the lens yellow? Idk curious to know what i can do to make the color deep vibrant yellow.
![](http://i54.tinypic.com/2iietrt.jpg)
Thanks
Thanks
Ok...I wish I had a pic of the hid's. I will try to explain. The big connector that connects the bulb to the ballast instead of connecting it the correct way. Turn one end upside down and connect it backwards. Make since? If not I will try to find a pic. If you have done then the other two tabs that are the small wires off the bulb. Make sure the black wire is connected to the wire coming from the fog light itself and the blue wire connects to the connector inside the black cover for the bulb. If this is confusing....which it is to me and I wrote it I will take pictures mmk? Just let me know. If you have done these already let me know. I will think of something.
i mean like i havent put hid lights on them yet because they dont come on at all. i even turn the switch all the way on but nothing im going to have check futher into my fuse and relay
I bought a set of HID H3 fogs fogs from a vendor on this site 6 months ago and never installed them. Honestly, I took the splash guards off and started looking at the wiring. None of the harnesses matched up and I had a feeling that this was going to require some custom work. I'm not sure what other people do to proceed, but I left my stock ones alone.
LaminX work nicely too. You can buy a sheet from their website (www.lamin-x.com), no regrets with the yellow overlays for my fogs.
UberNoob
06-20-07 02:14 AM
