2jzge to 1jzgte trans swap
I'm in the middle of swapping my GE trans for a a341 from a 1jzgte and I noticed the sensors are alittle different. My question is if anyone knows how I can splice the GTE sensors to my GE harness for just the trans? Thanks for any help
I believe it's from a chaser. Can't get pics of the plugs now cause of the rain but I will when it clears up
Edit: I think the main problem I'm going to have is the 1jz trans runs off of a cable for the speedo. Which I don't really mind since my speedo doesn't work now anyways. I just want it to drive and shift fine I have a gps for keeping track of speed
Ok so I got everything swapped over and the 1jzgte trans put in the car but it's not engaging in gear 100%. Not sure if it's something I did wrong when I put the valvebody back together or the trans slipping. I can put it in gear and have to rev it to get the tires to spin with it on jackstands. Curious if anyone has any tricks to test certain problems
The car moves under it's own power but feels like a high stall car. Revs to around 3k-3200 before it moves and I can feel the trans shudder alittle if I try to move the car too fast. Still lost
YeA 2jZ
Performance & Maintenance
10-26-08 04:47 PM
