Replacing head gasket, any suggestions?
Thinking about replacing my head gasket. Is there anything else i can do while i'm there? sparkplugs etc, any other seals that are close to get to that i should know about?
was thinking about picking this up:
http://forum.clubna-t.com/showthread.php?t=3179
Also want to do water pump/timing belt, but thats another story.
Are you going NA-T? If so you can send the head off to get ported/polished while its off. Also, nows a good time to do Cams.
From the link you posted:
Add:
-Timing Belt
-Water Pump
-Plugs
-Wires
-Cap
-Rotor
I strongly suggest that if you are doing your head gasket you do your front crank seal, cam seals, stem seals and intake/distributor gaskets. You may as well, you'll be looking right at them at that time. A great value at $245 shipped.
-Timing Belt
-Water Pump
-Plugs
-Wires
-Cap
-Rotor
I see abit oil grease around it, and i eventually hoping to throw a turbo on, so i want to make sure all the seals are strong. where's the seals located? a picture would be much appreciated.
was gonna do it myself or have my mechanic helping me out.
WadeLovell
Performance & Maintenance
20
01-06-13 07:29 PM
