How do you remove wood trim on dash?
Courtesy of Iain Wiltshire - LSOC
The 3 vents that are in the 'wood' strip, require you to remove the glove box, you do this by taking off the horizontal plate just below the 'box and then remove the 'box all the screws are easy to find, be carefull of the spring near the door, don't lose or bend it. There are 2 screws behind little square covers take them off and the 3 wing nuts that hold the wood strip and the vents in place can be undone, spray some WD40 on them and wait a little while, the end nearest the speedo binnacle is held in place with just a clip, use a sucker or a padded pry tool to get it off, dont try to 'lever it off without padding, you will damge the binnacle covering. Start now and by 9'o'clock tonight you will have done the job, even with no experience.
