No power light on auto dim Rear View Mirror
I searched but only found threads about auto dim mirrors only working partially. On my 97 Sc300, the green light used to be on indicating that the auto dim was functioning. I just noticed for about a month that, the green power light is no longer on and I cannot toggle it on or off. The mirror just stays in day mode. Is there any fuse I can check or do I need to replace the mirror. Thanks guys
It might be the wiring connector in the mirror. If you have had someone change your windshield there is a fair chance that they pulled on the wiring during the process and damaged the connection.
Nah, original windshield. When changing my dome lights to LEDs, I blew a fuse for the dome light, not sure if it was before I blew the fuse that the auto dim wasnt working. It was functional though at one point. I checked under the hood for a fuse for the mirror, couldn't find anything. I will try to check the wiring to see if it's getting any power over the weekend
