NGK Coppers
Yes, I did search the web. Yes I did search CL and other Supra forums. However, I can't find my specific answer.
I'm going to change my plugs, however, I've always ran copper plugs in all my other cars, including my rb25.
However, not sure if 2j's like coppers. I've always dealt with Nissan. Stock plugs are the laser platinum with a 5 for a heat range BKR5EP11. I'm thinking of getting NGK BCPR5ES-11. It's the same heat range, same gap, just haven't seen anyone run these. Reason I'm asking is because, are people not running this plug for a reason? Or do people just like to spend 60 bucks for spark plugs.
I have always ran copper. Everyone I've seen in the Nissan community swears by coppers, but when I get in the Toyota scene, coppers aren't even talked about.
I don't like iridiums and I've never used laser platinums, and I don't want to.
Normally I wouldn't ask and just do it and see what happens, but seeing that the intake design is retarded, I was hoping I can save myself about an hour and a couple of bucks by asking. Thanks.
I'd appreciate any help.
Joel
Joel
Well Joel, I think you just nailed it. That alone is reason enough to want to go with a longer life plug. I don't know what you have against Platinum or Iridium, but either of those types can be had for way under $60, and they will certainly last longer than your coppers. If you're dead set on it, there is no reason you can't run copper plugs though.
I don't mind at all changing the plugs. What I do mind is wasting my time. Let's say the 2j didn't like coppers. Well I just wasted a good 45 min to take them back out and replace them with something else.
Yes coppers don't last "long" compared to others. But then again, they do last a while. I don't mind changing them one bit. It's all about time.
I'm just going to go ahead and make a trip down to checkers and pick them up.
Thanks, you guys for the response!
You searched? Really? What did you type?
Bacause I got
https://www.clublexus.com/forums/per...periences.html
This thread. Its pretty good. Did you look in the performance section? Because that where all the spark plug info is.
Bacause I got
Currently in the middle of changing the plugs. I decided while I was at it to compression test my car, see if my rings are ok. The tester I was using broke, so now I'm contemplating whether I should wait until tomorrow, or go 30 minutes from where I live to borrow my friends tester.
Once the test is done, the new plugs will go back in, new pcv valve will go in, and everything will be put back.
Just finished up the new plugs. I love them, as usual from my past experience. Top end is WAY more responsive. God only knows how long those iridium plugs have been in there.
Also realized how many hoses I want to change. 15+ year hoses crack very easy. Going to order a driftmotion power steering hose right now as well.
Sorry but I personally think paying that much for plugs is retarded. Even if coppers don't last that long, STILL at the second replacement, they will be cheaper than buying iridiums.
I spend 14 bucks on the copper plugs
It's the high pressured power steering hose. Since I drift and my steering takes a lot of abuse, my hose started to leak due to too much pressure. The driftmotion one is this one
http://store.driftmotion.com/static/...k3mk4sc300.php
Driftmotion power steering hose? Which hose does this replace?
