Salt Sucks!
Salt Sucks!
So today I decided to swap back to my summer wheels and tires since the weather is nice now. I had been hearing some odd sounds from the rear driver's side of my car so I figured this would be a good time to check things out. I was thinking it may be the UCL or the strut or something. Both looked fine, bushings all looked or, axle was fine. Everything that was there was fine. Then I noticed what wasn't there.
I got the car last spring and the PO said that he stored the car every winter. Lies, all lies!
Anybody got a spare subframe lying around?
And ignore the dirt. I usually keep it much cleaner. Had to make a small trip down a gravel road last night. I'm headed to the car wash shortly.
hey if your going to get a whole subframe try to find an mk4 supra subframe. if you look through scotturnot's builds you can see the difference in design (it'll still bolt up) but these differences should make help the car in turns. now if you have the factory wheels or 16's then get teh non turbo version but if you have 17 or larger high disk wheels then you can get the us tt subframe with the upgraded brakes
heres scotturnot's post on the rear subframe.
Well Guys, I have been working on cleaning up the TT subframe assembly to prepare it for the install. While doing this I have been doing a side by side comparison of the TT subframe verses the Stock SC. First off I Would like to say, Those who say there is no gain in swapping the entire unit are wrong. Here are some of the differences I have noted.
Both the front and rear Lower Suspension links are are about 3" shorter
This was done for a couple reasons I suspect. Shorter links mean less flex and better control for cornering and drive trane shock from a manual tranny. They could shorten these since the Supra didnt need the extra travel due to it being lower than a stock SC I think. Stronger!
All four Body mount rubber bushing are a much stiffer Durometer along with being heavier built.
This again will serve as a much harder launch with a manual tranny. It is very clear this was intended for abuse! This is a Big Deal
Diff mounts are also stiffer rubber
Same as above
The actual subframe has subtle differences in construction.
These changes reinforce the frame for added drive Trane shock. Things like more boxed in arm mounts, More stamp reinenforcment in areas that count.
Of course don’t for get the Sway bar.
Tying the sway bar to the actual subframe instead of the body is for business type cornering.
And TT brakes to boot!
At this point I am pleased that I chose to swap the entire subframe assembly.
Same as above
Same as above
Same as above
BLUE = Not part of the subframe
YELLOW =As I said previous the difference in actual subframe construction is dependent on year not the chassis from which it came.
i know its not part on the subframe maybe i should rephrase what i originally said. i meant an entire dropout. in this case you do get some of those potential upgrades. hey im not trying to argue here. im just trying to help someone, not getting into a contest to see who knows more. once again i probably should of said an entire dropout. one more thing...adding in supports actually does help with strength.
triumphtr7@hotmail.com
What about a GS300 subframe? I found this ad saying they're interchangable and I happen to have one of those in storage. I'll dig it out this week and take some measurements, but was wondering if anyone knew.
And an email is forthcoming about the one I have.
GuoxJason
CL of Southern California
45
10-08-10 11:15 AM
Burst32
03-16-07 01:03 AM
