Stuck need some help, cant get steering into knuckle
Im almost done putting my sc back together and getting it to run, and I ran into a problem. I cant get the screw on the steering rack to go into its hole in the knuckle
for those that may need a quick visual reminder of what I'm talking about
The ball joint screw just wont go in the hole, i've soaked both the screw and the hole in pb blaster. Tried using everything from a rubber hammer and sledge hammer to get it in damn thing just wont budge into the hole
If I'm not mistaken I believe the bolt of the tie rod ball joint is inserted from the bottom to the top, with the nut and cotter pin above the steering knuckle
But if the end is mushroomed then the problem will still exsist even though the hole is slightly tapered but not going to get a nut on there without some serious work.
Originally Posted by ArodDaLob
^this^
thanks guys I figured i had to be doing some thing wrong
the tapped end is mushroomed but not that bad but i need to clean up the threads anyone know what size this bolt is?
