possable transmission problem
yeah a visual inspection somtime will work. look for cracks or pitting in the rubber. if everything looks good try to pinch the rubber in the mount if it is not ferm then chances are it needs to be replaced.
its amazing how much vibration a bad or semi bad mount can cuase.
The only reason I have any hesitance is the fact that it has 138k and I don't know if it has been done before. If it hasn't and I change the fluid it could kill the tranny.
your car....your call.....but my money is changing the fluid...ESPECIALLY if it smells burnt and or looks old/bad. Just purchase a quart of new to compare it's looks and smell. The logic of leaving it untouched I guess means that you will never change it for the life of ownership?........how long/miles is that?......You can always siphon out a bit of trannie fluid with the use of a very small rubber hose (any good hardware store sells clear small rubber tubing) running it down thur the trannie dipstick hole. Suck out a cup or two and get a good look and smell of the stuff, just remember to replace with the same amount you removed.
I'm changing my tranny mount and expecting a few problems to go away, based on the reviews/experiences people have had on CL after changing their mount. Fixes possibly include vibratons, slippage, loss of torque, etc. And for only $120 from the dealership it's not gonna kill ur wallet to give it a shot..
i understand your train of thought but its not engine oil. thanks for your imput though.
i was able to get ahold of lexus and track down service records.(pain in the ***) the fluid was replaces at 60k, my pan has a leak so i will be replaceing gasket and the filter and fluid of course.
mohep
13
02-21-11 09:58 PM
asadchinoy
02-18-07 05:47 AM
