Help with my sc400
Help with my sc400
Just last night i was driving my car to my girlfriend house and notice that my belt was squeaking really loud and also it started smoking. When i pulled the car over i notice that it was alot of heat coming down below by the exhaust manifold only on the driver side. Can you all tell me what you think it is? Im leaning more toward gasket needs to be replaced.
Would that create that amount of heat that is coming off. My auto teacher thinks my heater pulley is seizing up because of where the smoke is coming from and also the squeaking
maybe you should start the car in the day time check the engine bay out.That way you can see exactly where the smoke is coming from. Also turn the ac on and off to see if there is any change.
I did that and notice that its coming down below right by the ac clutch pulley.
Just notice that my idle pulley is not rotating like all my other pulleys. So its seized up. Nd the heat I'm guessn its the gasket off the headers is in need for replacement
sc300Super
12-03-13 06:56 AM
vintagelex
04-28-13 03:53 PM
