240sx Hub to SC hub?
My friends selling a whole quick release set up from his 240 and I was wondering if it's possible it will work with my sc? I can't seem to find any information about it on here, but def would like to know or have any help with this! Thanks!
nissan hub will not work. i own an sc and a s13 convertible.
you can get a hub for an mk3 supra, mk4 supra, and 2nd gen mr2 and those will work.
when you use the mk3 supra hub, as i am, you need to remove your clock spring for the airbag and cruise control. to do this, you need to remove the underside of the driver dash and unplug the harness below the ignition cylinder. there is no plug right at the steering wheel hub. without doing this the hub wont fit at all.
SoarerGold
SC- 1st Gen (1992-2000)
18
05-19-11 07:37 PM
