Sc 300 Project " in progress "
ok so first off here is how its wired
Sry its from my I4
the bottle is mounted to our wood in the back of the car, i do plan on replaceing this with a sheet of aluminum i just havent got that far yet =)
After you mount the tank feed your line with aid from a metal coat hanger threw the passenger side back seat. you will need to remove the carpet from the passenger side floor to get threw the firewall. DON'T BE A LAZY DUMBASS LIKE ME, i removed the AC drain hose completely and used its hole. this was retarded cuz after i was done i realized now my ac will drain water directly on the ecu! WTF was i thinking!
OHH and BTW get a long hose, mine was Just long enough and i wish i had an extra 5 feet think i had a 20 foot wish i had a 25-30 foot hose. see why below
if it was longer i would have had much more slack in the hose, Also if i were to run it again i think i would rather run hose under the car than threw it. just an fyi
Once you have it threw the firewall, also feed threw 2 wires make them red and pink, makes it easier for you later. then i cut a notch about 1.5 inch down the side of my ABS bracket as shown here.
After the notch was cut i used a torch to heat up the metal and fold it down, i then marked a hole using the bracket from the NOS Solinoid bracket, then i drilled the hole, bolted the bracket in place then heated the metal back up to put it back in place.
For the Micro switch, was SUPER EASY i decided to place it on the bracket that holds the cruise and trans cable, fold it at a 90 and mark your 2 holes, then i dismounted the bracket to drill my holes, put it back on bolted everything back up and wala! it also works PERFECT! inside the car it will not activate unless the gas is actually on the floor. this way you can drive all day with the nitrous on and not worry about spraying on accident, but even better is the fact that if you have never used nos before this makes it so you will not blow your motor. it guarantees you wont blow your motor by spraying below 1,800 rpm witch is the min spray point on a 2jz.
if you have any more questions let me know
Sry its from my I4
Cool stuff! I just grabbed a beat up SC to build for road racing! A buddy also offered to let me use an extra nitrous system he has lying around. It's not a salvaged title, but close. The guy I'm getting it from has put a mechanics lein on it to get the title. Once he has the title he sells it to me for 1k
Good luck with the build and keep us posted!
