Really Weird Climate Control Problem
I had that problem solved last week on my sc. I recently did a double din install and was having the same issue after my installation was complete. My outside temp gauge was even reading -22 F. So I went back in and pulled out the radio and the climate control unit together and come to find out that one of the plugs on the back of the unit was not pushed back in all the way... But before that I was outside my car going crazy with my electrician switching out with different ambient sensors, testing ac wires, etc... Now I just have to figure out why my ac lights keeps blinking and shutting down my compressor so often while driving the car. It is completely annoying. Especially in south Florida.
The a/c light blinking is normally indicative of the compressor failing..... Happened to me twice and both times it required a new compressor
its the in cabin temp sensor... i have a brand new extra one...$50 shipped... it cost me $65 if i remember correctly from the stealership...
message me if you are interested.
thanks
recycling imports. gmail .com
thanks
I had same problem and i replaced the interior temperature sensor, still does the same thing and still shows the same code (code 11).
now i am guessing it is my AC ecu problem?
How do I change the temperature to a higher degree? I tried to press the temperature button to lower it, but it is always at MAX COLD. I'm a new lexus owner btw. Anyone?
