My buddy made 371 @ 21psi with an hx35. He had a 2j ecu though on his. If you grind some 2jgte cams, you can pick up a solid 25-30whp and have a much smoother mid range power band.
well i do have 2jz-gte cams sitting in my garage, not sure if they are jdm or usdm spec (how the hell do you tell??) at 21psi?? why is he running such high boost, people can make that power around 18psi-ish or so ive heard
i wish man i still need piping and registration. ill try and come through with some other toyota peeps, i will come for april 16th alternative meet. you going to that one?
