1uz with r154 help!!
Ok so im doing a 1uz swap n a car n im trying to find out about what to do for the clutch set up. I dont want to just get a kit for $1-2k what i need to know s what bellhousing, flywheel n clutch set ups have been used n what modifications had to b done to make it work. Keep n mind hp goal s 5-6oohp turbo set up. Any info, specs n links b greatly appreciated.
You can use your stock bellhousing from the 1uz, but you'll need to have an adapter made up. I'm starting to search this stuff as well, so i can have all my sources available when I'm ready.
go over to lextreme dot com. That is where you really need to be for v8 info.
Goodluck
charley
Goodluck
charley
There is a lot more info on this in toyota truck forums... just use google...
I was looking all this up because I thought I was going to land this government job... but found out this afternoon the co-op program didn't hire everyone and I wasn't one of those hires.... bastards.... so yeah.... google and lextreme have the most info....common sense haha
I might actually sell my bellhousing adapter place, stainless clutch lines and hydraulic throwout bearing with spacers for my r154 swap. I decided to buy the whole kit so i will have left over parts (mentioned above) i wont need! PM me if interested! I also have a r154 driveshaft...if i have a 1 piece shaft made ill sell the oem one too
They actually have it done. They just have to put a 1UZ in a customer's MKIII with the R154 for "proof". Should be proven within the month I would hope. I believe they are only waiting on the customer to acquire a Tilton hydraulic throwout bearing so they can get the install moving along.
