SC- 1st Gen (1992-2000)
Brakes are dragging and hot.
Old 03-27-11, 03:47 PM
Kits73
Kits73's Avatar
Default Brakes are dragging and hot.
Hi guys. I replaced my front pads and rotors without problems. Pistons slid back in when pushed. After driving a few miles I noticed my front passenger brakes was dragging and it was hot. The drivers side is fine. Dismantled it and re greased the pins, still the same. Any suggestions will be much appreciated. I have a 99 SC300.
Old 03-27-11, 07:41 PM
MSBlade
MSBlade's Avatar
You can try flushing out the brake fluid to see if that will free up the caliper movement but more then likely you have to rebuild or replace the caliper.
Old 03-27-11, 08:18 PM
latinrice
latinrice's Avatar
sounds like you caliper is freezing up...
Old 03-27-11, 08:20 PM
broda805
broda805's Avatar
Caliper rebuild is fairly cheap and straight forward if it comes down to that
Old 03-28-11, 06:53 AM
Kits73
Kits73's Avatar
Do u know where I can find a rebuild kit? I am mechanically inclined but never did a rebuild.
Old 03-28-11, 10:23 AM
SChema
SChema's Avatar
I would forgo rebuilding a caliper these days. Since remans can be had fairly cheap. A lot less time consuming as well. You can call up your local parts stores to see if they carry them or not, worst case go to the dealer.
Old 03-28-11, 01:34 PM
MSBlade
MSBlade's Avatar
go re-man, do a bake flush and maybe replace the hose due to the heat. Just check the hose to make sure its still good if you don't replace it.
Old 03-28-11, 01:50 PM
GEZUP
GEZUP's Avatar
I got a rebuild kit from Auto Zone for $30.00 - $35.00. about a year ago.
Old 03-28-11, 02:01 PM
GEZUP
GEZUP's Avatar
http://www.autozone.com/autozone/par.../N-jd9mdZ8kole
or
http://www.autozone.com/autozone/par.../N-jd9mdZ8kn5i
Old 03-28-11, 07:04 PM
Kits73
Kits73's Avatar
I might go with a remanufactured one. It's only $60 at Autozone. All I need to do now is figure out how to replace it without screwing it up.
Old 04-04-11, 03:17 AM
latinrice
latinrice's Avatar
too bad you arent local, I woudlve done it lol.. just did my buddies...it's not that difficult..just don't use pliers on the brake lines
Old 04-04-11, 07:15 AM
ISFFUN
ISFFUN's Avatar
This is another case of the front right caliper seizing on the 300s. I think there's definitely a pattern but I'm not sure why.
corad
08-08-18 06:20 PM
sivikvtec
Suspension and Brakes
08-19-13 12:15 PM
gabzor
04-22-13 09:41 PM
peelsSC300
16
12-19-11 03:27 PM
pinoybboy
05-02-06 03:51 AM
Quick Reply: Brakes are dragging and hot.
