im going to try to make it to smittys bbq on sat if i can. 19x8.5F/19x9.5R +15mm offset all the way around with 15mm spacer up front
They look great. What tires/size are you running? I'm really interested in the back because I have a similar size/offset and I'm deciding on whether to go 235/35 or 245/35
Seriously. This is how it's supposed to be done!!!
Okay thanks for disclosing your offsets man I was dieing to know... Okay so you're saying that effectively you're running a 0 offset at front and +15 at rear????
Any reason why youre running the spacers at the front and not the back??
Thank you, yes thats correct 0 offset front and +15 on the rear, the reason is the front with +15 in the front was not flush enough for my taste, on the rear it has no room to put any spacer on i dont think i can even put a 5mm on there unless i pull which i didnt want to do.
