SC- 1st Gen (1992-2000)
hit a pothole,now she wont start....
Old 04-06-11, 05:04 PM
jubay
jubay's Avatar
Default hit a pothole,now she wont start....
I hit pothole this morning,and the car shut off,I pulled over and tried to restart it,but it starts then cuts right off,just wondering if anyone else experience this,if so could u please tell me what the deal is
Old 04-06-11, 05:06 PM
1jzchris
1jzchris's Avatar
Did you relocate you harness when you put on rims and lowered. Check you harness under the driverside fender.
Old 04-06-11, 05:08 PM
FatBrian81
FatBrian81's Avatar
Have you relocated the wiring harness in the drivers side front wheel well ? If not I would pull the wheel off and see if there are any wires hanging out of it.
Old 04-06-11, 05:22 PM
jubay
jubay's Avatar
nah i didnt relocated anything,but i'll check
Old 04-06-11, 05:28 PM
abounly
abounly's Avatar
Probably your harness. With your big rims in your avatar picture im sure you ate through your harness protector
Old 04-06-11, 05:29 PM
FatBrian81
FatBrian81's Avatar
10 bucks says you'll be relocating something soon.
Old 04-06-11, 05:35 PM
1jzchris
1jzchris's Avatar
i wnt in on that.............lol
Old 04-06-11, 05:43 PM
xspsi6
xspsi6's Avatar
Could be the fuel pump inertia switch.
Old 04-06-11, 05:48 PM
FatBrian81
FatBrian81's Avatar
You would think a pothole that bad would have bent a rim. Would the inertia switch allow the engine to start at all ? Other times when that have tripped on family members cars it has always resulted in a total no start situation.
Old 04-06-11, 05:50 PM
1jzchris
1jzchris's Avatar
thats a fancy name for a saftey cut off switch.............................lol
Old 04-06-11, 08:01 PM
Abelo
Abelo's Avatar
once i hit a dip in the road and my car shut off turns out one of the battery terminals came loose. check as many plugs and switches as you can, and also you're alternator.
Old 04-06-11, 08:05 PM
iridebmx
iridebmx's Avatar
check the function generator to get some high amplitude waves going in your car too!
Old 04-06-11, 11:04 PM
ScBouncE
ScBouncE's Avatar
Im pretty sure the battery has no purpose in the car after its sparked the engine on. Thats where the alternator comes in
Old 04-06-11, 11:32 PM
Superjatt
Superjatt's Avatar
Check you battery terminals. Check if they are clean and stuff, i used to have a jeep with loosie loo battery terminals and everytime I would mess around it would turn off!
DO IT!
Old 04-06-11, 11:38 PM
Abelo
Abelo's Avatar
if the battery becomes disconnected its a open circuit, so the car wont run. im pretty sure the alternator runs through the battery even though it doesn't use its power. the battery is used just for cca to start the car and to complete the circuit...
thats why my car turned off when the terminal came loose.
Quick Reply: hit a pothole,now she wont start....
