sc400 cluster into sc300 question
i know this have been covered but cannot find what im looking for.
i have 93 sc300.. and my cluster is busted.. i found a sc400 cluster on the junkyard.. is this interchangeable? which part i need to switch over to make the sc400 cluster work with sc300
There is also differences between years. 92-94 are are interchangable, 95 and 96 are swappable (I think) and 97 + are the same (I think).
Differences in clusters include backlighting design, needle color and polarity, 4 speed auto and 5 speed auto, green lights on indicator, and of course manual vs auto in the SC300.
All the above is 300 to 300 - 400 to 400 only. I just wanted to point out there are many differences in clusters.
Depending on how bad and where its burnt (I cooked one too) you can repair it. If you carefully scrape away the green stuff with a razor to expose the copper, you can solder wires to it. If it melted at the connector... you could still solder, but it would be more of a pain.
mostone131
SC- 1st Gen (1992-2000)
08-27-12 06:21 PM
WadeLovell
Performance & Maintenance
05-29-12 06:29 PM
thegadget
12-23-07 10:46 PM
