SC- 1st Gen (1992-2000)
Hub Centric Rings & Nissan Wheels
Old 04-11-11 | 07:25 AM
jjffyy's Avatar
jjffyy
Hmm really? I remember someone else on here had their aluminum rings fused onto the hub as well.
Old 04-11-11 | 10:59 AM
lfrers's Avatar
lfrers
Good info on the plastic hub rings. I just ordered some aluminum ones. Dont matter to me if they fuse because my spacer hub is aluminum too so if it fuses to my spacer it a plus. Not much I can do about it anyway. I'm guessing they are better than plastic so oh well.
Old 04-14-11 | 10:51 PM
saleens281's Avatar
saleens281
So to confirm since when I searched there was no real confirmation in one thread... To fit nissan wheels you will need OD: 66.1 & ID: 60.1. I attempted to put on my rims this morning and well it didn't go as planned. I had to shave the rears but because of the 19x10(r) +33 Offset on a 285/35 tire it still rubs. I need to find a person here local to roll the rest and pull my fenders.
Old 04-14-11 | 10:57 PM
lfrers's Avatar
lfrers
The ID is 60.1 but you really should use a caliper to measure the OD from the hole in the center of the wheel. It may be diffrent that what your expecting.
Old 04-14-11 | 11:07 PM
saleens281's Avatar
saleens281
I would agree... and as lfrers has mentioned it may be different from what your expecting.
I can only refer to OEM Nissan wheels... the 18/19 GT Rays to be exact.
Old 04-14-11 | 11:27 PM
100degrees's Avatar
100degrees
MATERIAL: POLYCARBONATE (METAL VERSIONS RUST OVER TIME)
INNER DIAMETER:60.1MM Toyota
OUTER DIAMETER: varies
$10 on Ebay
Sorry for thread jack but where can I find them for $10 ebay? Anyone have a direct link. I'm in a similar situation and I can't find the size needed on ebay.
SilvaIS350
GS F (2016-present)
16
12-09-18 03:32 PM
colin415
07-04-14 03:35 PM
garethr
Wheels, Tires & Brakes Forum
07-09-07 07:48 AM
ted920
04-26-04 02:31 PM
