Full Gasket Set 3.0L 2JZGE DOHC 12V can fit a 1JZ engine
what will fit and what wont fit>>>>>>>>Full Gasket Set 3.0L 2JZGE DOHC 12V can it fit 1JZ Engine
Non of the important (aka expensive)gaskets. the headgasket from the ge motor is a single layer gasket. The 1j requires a three layer gasket. The intake and exhaust gaskets are different as well. You can get the 1jz gasket set from driftmotion.com or call champion Toyota in Houston, they can special order some 1jz parts
