LED lights in turns/corner/city lights... No workie
hahaha
...im glad SOME people here have a sense of humour!
=D
honestly - im out. you're on your own, friend. haha
no seriously it's hard to diagnose when im sitting here at a computer in west australia and your...
...where ever you are. cali?
like if you said "everything was working before"
then i'd be all up on you like
"turn the lamp around derp"
or
"check the fuse"
but if nothing was working before then... no idea man..
wait, have you tried yelling swear words at it? =/
=D
or
"check the fuse"
check the pigtail connectors on the headlamp housing, make sure they are actually connected. Someone may have disconnected them. It goes bulb holder, to pigtail, to harness.
hahaha
=D
or
"check the fuse"
=D
or
"check the fuse"
I have turned the around and around the dont work. I haven't checked fuses though. Just havent had a chance yet for that
I will pull it all apart tomorrow maybe and see if it works. It's like one of the easiest things in the world and its not working. Freaking weird i tell ya. Oh well I just need to diagnose more.
well if that's the case then maybe it's not the fuses? maybe previous owner cut a wire?
easy way to diagnose..
buy a $2 fault finder lamp from hardware shop ... put black wire onto an earth
and plug trouble lamp into your city light *****.. see if it comes on. if it does - your car is fine. and it's the bulbs at fault
do the same with all your other stuffed up lights
if the trouble light doesn't come on... then... the plot thickens.
yeah australia's gone crazy for the iphone - we much prefer it to what we used to use..
...we used to stickytape a disposeable camera to a cup n a piece of string.
we called this invention... the "camera phone"
but iphone seems to do it all!
