SC- 1st Gen (1992-2000)
Flat bottom SCXXX...
Old 04-17-11, 05:29 PM
MSBlade
MSBlade's Avatar
Originally Posted by chnk
they make that out of abs plastic, if the mpg gain is like 3-4 mpg i might consider taking time and doing this lol
+1 on this but like others have said, would worry about the heat
Old 04-17-11, 06:49 PM
Luxor
Luxor's Avatar
That looks very very very very sporty
Old 04-17-11, 06:58 PM
sc4doubleO
sc4doubleO's Avatar
Good job on the cuts. This would be great for high speed runs.
Old 04-17-11, 07:03 PM
GZZ-TT
GZZ-TT's Avatar
There are lots of sports cars that have flat bottoms, I'm sure it'll be fine; heat rises anyways. It's flat bottom women you have to worry about.
Old 04-17-11, 07:35 PM
MDSC
MDSC's Avatar
yeah alot of sports car have this but only in the middle not under trunk area and around the mufflers like this one
Old 04-17-11, 07:39 PM
cartmill
cartmill's Avatar
why is everyone so worried about the heat? they left the exhaust sections open...
Old 04-17-11, 07:47 PM
Dade305
Dade305's Avatar
i feel like my iq just dropped from reading that.. not to mention the music made my ears bleed. on the upside, if they sold this kit for 50 i'd buy it lol
Old 04-17-11, 08:24 PM
-Samurai-
-Samurai-'s Avatar
Hey at least all the parts under there will stay clean and free from debris and dirt/salt kick up. Interesting idea. I kinda like it...
Old 04-17-11, 08:28 PM
NEbiker10
NEbiker10's Avatar
And you could easily clean it with a hose, No where else that salt could hide
Old 04-17-11, 09:16 PM
QwkSC
QwkSC's Avatar
For the car that already has everything else done too it.
Old 04-17-11, 09:45 PM
scottys209
scottys209's Avatar
Get underneith your car and touch your trans while it's been driven in stop/go traffic for an hour and see.
@0:17 it looks like mdf wood not abs plastic..... I hope that was for just a test fit, or else, well, watch the episode of top gear where they made a renault a racecar and see what happens when you use wood. I may be wrong, and probably/hopefully am, but it looks like MDF.
Old 04-18-11, 04:40 AM
ogre
ogre's Avatar
probably used the mdf as a template otherwise that ***** would be heavy as hell. salt/sand/etc would be able to collect around every suspension piece that moves because there is really no good way to seal around those areas. all in all i cant see you getting any increase in milage and it almost seems to me like it may cause some high speed lift issues. plus on an auto trans it seems like it could cause overheating and eventually failure
Old 04-18-11, 07:25 AM
Kohinoor
Kohinoor's Avatar
id love to have one
Old 04-18-11, 07:58 AM
718murdoc
718murdoc's Avatar
The owner of the car says this application was a trial & error deal,(test fitting templates) he claims that the material is very resilient & has been trouble free since the final installation. As for heat, There is a small space between the panel and the car for heat to dissipate. As an added precaution I would add a heat shield to the trouble spots.
Old 04-18-11, 08:34 AM
Klaus
Klaus's Avatar
O RLY?
Quick Reply: Flat bottom SCXXX...
