Pulled the trigger, NA-T in the works.
#65
yes, i do have emissions to worry about. My smog test is good for 2 years i believe, by then ill have a test pipe fabbed up with a high flow cat. During that time i will have a full 3 inch straight pipe.
So far, yes. Ive been boosting it on the highway a good bit so ive been surely burning gas like crazy.
One odd thing i noticed is that the fpr adds fuel under boost. Ive had to use my safc to PULL fuel instead of add it.
#66
Oh, so you have no clue where the smog numbers are, bummer.
I have the same power goals as you accomplished, but I have a 96 which is OBDII, we have the plugs in test and visual.
I guess I need to talk to an inspector to see just what I have to do to pass.
#67
In colorado, they dont even do a plug in anymore. you can pass with a CEL now. My car is tuned great, runs like an NA car out of boost and hits no higher than 11.2 during boost. If i failed emissions id be surprised. When i have to test I will turn the boost WAY down and lean it up a bit just in case but Ive boosted cars before with no issue.
#70
I think so. Ive hit the rev limiter a couple times, but wasnt really aware of the rpm. Itll get headwork when I take the head off. hopefully 272's. I love the way they sound at idle.
