Installed ls400 bbk and now has a low speed noise?
New rotors and pads along with stainless brake lines etc now I have been pulling my hair out trying to figure out this noise which you can sort of feel it in the pedal at speeds lower than about 10mph.
I put new shims in as well so everything was done properly and the worse part is I do this for a living and this needless to say has me stumped![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Here is a description of the noise...
At speeds below 10 mph right as the car is coming to a complete stop it has a vibration sort of which could almost be called a grind but I have had the wheels off 4 times trying to get exactly what was going on and everything is looking as it should.
Stopping power is as it should be so decrease in performance, I would almost describe it as if the rotors had oil on them which btw I used brake cleaner to get the shipping oil off
so imagine a slight skipping vibration and low low speeds kind of like when you are in traffic that is almost at a dead stand still and you are just letting a little pressure off the brakes and it makes a noise at all 4 corners as the car creeps forward.
Any input is welcome![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Thanks
Thanks
Have you properly seated or broken in the brakes?
First, 60 - 5, three to four times.
Then, 35 - 5, five to seven times.
Once you've completed the cycles, drive around to let the brakes cool off. Try not to come to a complete stop while going through the cycles. Complete stops may imprint friction material from the pad to the rotor.
Sounds like you've done everything properly so can't I pin-point the exact problem. I'm thinking the brakes just haven't quite seated properly yet; since you've replaced all four corners, the sound and vibration is multiplied as the pad and rotor forming the contact pattern.
I think you may be on to something but I have installed hundreds of brake changes and never once had this issue.
I will just get some miles on them to bed in some more as it sounds like we are thinking along the same lines here.
Gimpster- I used the ls400 bolts which were a bit shorter but I did double check that to make sure there was no contact etc.
