Just got my headlights restored without plastic polish!
I don't have pics at the moment but they look like new and he didn't use any polish.
What I'm wondering about is the clear liquid he was carrying in a water bottle, he poured it all over the headlights and took off all the yellow haze which I thought had polished a month ago, it didn't damage my paint and you could actually see the yellow stuff coming out of them.
After he cleaned them up with that liquid and sanded them with fine sand paper I was like damn they look worst than they were before, I couldn't even see the projector through, but they he applied some coats of acrylic laquer and damn they look like new now.
Has anybody used this method or know what he poured on the headlights that cleaned them up that good and didn't damage my paint?
I know of at least one company. Ever-wear makes kit for head lights.
"Ever-Wear Headlight Restoration Kit Restores the appearance and performance of discolored cloudy headlights. Make headlights shine like new. Don't spend hundreds of dollars replacing your headlights. Most of today's vehicles no longer use glass headlights, they are made of plastic material with a thin protective laminate film over the lens. With time, the sun's UV rays and contaminates such as acid rain, salt and road debris degrade and discolor this coating. Halogen headlights operate at very high temperatures, contributing to laminate oxidation. Oxidation and deterioration results in a cloudy film that can diminish headlight candle power and light output, significantly reducing visibility and nightime safety. The Headlight Restoration Kit provides the preferred cost-effective alternative to replacement featuring polymer laminate coating replacement. Ever-Wear's unique process removes the oxidized film, polishes the lens and applies a protective UV-resistant coating. The restored headlight is clear and performs like new, superior to wax or silicone coatings in both appearance and performance. Easy to apply with instructions included and features: Oxidized laminate removal-improves appearance, night vision and safety Three step wet sanding- completely removes OE laminate coatings, smooths the lens surface Lens cleaner/wipe- prepares the lens surface for coating Liquid polymer application- provides UV protection, fills minor imperfections and hardens to form a crystal clear laminate layer equal to OE "
This puts new "clear coat" on the headlights. I am sure there are others out there too
You can not get a proper bond to the headlight as clear coat is meant to bond with base coat so it's only a matter of time before a small rock chip will compromise the bond and it will start peeling and flaking when we were taught about clear coat in collision repar technology class in college this subject came up a lot so the instructor took a yellow headlight from a junk car and wet sanded and polished it to the point that it could pass as new again.
I don't see the big deal here, plastic polish or wet sand, it's the same thing removing a thin layer of material. The junk they put on first was just to clean any road grim off I'm sure.
Location: Sideways on the Yellow Brick Road! < Thats KS!
There is a UV protectant spray that goes on like paint but its not a paint, are you sure they didnt use that? I plan on ordering some, I have the companys name on my desk at work, they had a booth at SEMA.
The higher end headlight restore kits come with the UV protectant coating. If you don't get a good coating to protect from UV you will be back in the same boat again sooner or later.
