SC- 1st Gen (1992-2000)
95 sc400 no crank problem..
Old 04-24-11 | 03:48 PM
ZPEED's Avatar
ZPEED
Default 95 sc400 no crank problem..
my car won't crank up but i heard clicking sound, the battery is fully charges, battery terminal cleaned but still no crank. i need ur help guys..
i suspect the starter but i replaced a used one last year.
Old 04-24-11 | 04:25 PM
SChema's Avatar
SChema
Dead starter. Bummer that you'll have to pull the intake to service it.
Old 04-24-11 | 04:34 PM
ZPEED's Avatar
ZPEED
i replaced the starter last year but it was a used one.. maybe you're right..
Old 04-24-11 | 06:18 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Its about an four hour job. With basic hand tools. Would clean the entire throttle body and replace the two rubber coolant lines under that as well. Jmo. Good luck and keep us posted.
Old 04-24-11 | 07:07 PM
ZPEED's Avatar
ZPEED
I'll make it one week job cause my time is limited , I have to replaces the starter, spark plugs and valve cover gasket, I'll do it once.
Old 04-24-11 | 07:12 PM
ScAmor's Avatar
ScAmor
Could it be the alternator? I had to swap mine when i put in the 12"s because it couldnt keep up.
Old 04-24-11 | 09:48 PM
ZPEED's Avatar
ZPEED
lots of work man..
mdrag
12-15-15 04:40 AM
gd3tyrone
12-03-13 12:32 PM
flashover9
Maintenance
05-21-13 05:56 PM
billydpowe
06-02-10 09:04 AM
gserep1
08-04-06 10:29 AM
