Stupid PW problem
Ok so I have a 94 sc300 and my passenger window doesn't work. When I put power to the motor it works but niether switch will work. The switch only works to make it go up but not down. Could the motor be bad or a wiring problem somewhere?
It could be either the wiring OR the master switch. The ground path for the passenger window operation is routed through the master (driver side) switch. In my case, I had a passenger window that would only go down, but not up on either switch. After verifying the motor functioned fine, I was thinking it was the wiring in the door jambs. I traced all that out and found it was still good. Then I followed the circuit path back to the master switch and found it to be bad. Swapped it out and it's been fine since. The FSM has a good troubleshooting section on the window operation.
DeviousGS430
RX - 1st Gen (1999-2003)
12-20-15 02:32 PM
LRP_LS400
08-29-07 04:06 PM
