Hey 1JZ guys what kinda power you putting down?
You should be at or above 500whp with that turbo on pump 93 with good tunning....the injectors will be your limiting factor.
here are a couple vids of the SC mentioned above....correction runs were on 19lbs
http://www.youtube.com/watch?v=wbKDV...layer_embedded
http://www.youtube.com/watch?v=ri49H...layer_embedded
http://www.youtube.com/watch?v=1IHu9...layer_embedded
sorry no vids but im gonna try and get some soon
I have been to the track a couple of times.
@9psi it went something like 15@98mph 2.4-60ft
@18psi it did 14.3@105 2.5-60ft
its pretty sluggish down low (hence the 2.5 60ft), but keep in mind i have a 3.76 rear end and a stock stall converter. Once it gets going though it takes off, i can hang with stock c6's on the top end.
The next mod im doing is taking the stall out and sending it to boostlogic for a re-stall. I believe the stall is going to be the same as the stock sc300 2jz na, which means theres no aftermarket option. Zohair@BL said they can get another 1000rpm out of the stock converter, which should help a lot. I might do cams while im waiting for the stall
thanks mayne
mine is daily driven as well
thanks mayne
Thanks...I no longer own that car,In the process of building a NA-T with built TT auto trans.
also Dre is gonna tune my car
