Hey 1JZ guys what kinda power you putting down?
#79
Yes, you are correct but it kinda all depends on the fuel setup you wanna go with...me personally id rather you a GE block with 1JZ head cuz the compression is higher, so if you use pump gas then you wont be able to run as much boost as a GTE block, but if using race gas or e85 boost level doesnt matter.
But if you like running jus pump gas at high boost levels all the time a GTE block would probably be the best bet.
#80
Yes, you air are correct but it kinda all depends on the fuel setup you wanna go with...me personally id rather you a GE block with 1JZ head cuz the compression is higher, so if you use pump gas then you wont be able to run as much boost as a GTE block, but if using race gas or e85 boost level doesnt matter.
But if you like running jus pump gas at high boost levels all the time a GTE block would probably be the best bet.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#81
not that im wanting to blow up my 1jz. but now that i've established my setup.
swapping over short blocks to a 2jzgte will be cake. the compression is lower than a GE as well. and lastly im not running a long oil line from the oil filter housing all around to the turbo. it looks dumb.
and easier to source parts for 2jz
i am na-t with ge block and you will never see my oil line.
who is talking about 1jzge? i didn't get that part
easier to source parts for 2jz what are you talking about ? i didn't understand that ..
When we talk 2jz please let's not bring up that oil squirter crap , it's getting old now !!!!
and 8.5.1 is old technology , even supra guys don't run that CR anymore on their build, and who runs 8.5 unless they have too
You believe gte block and 8.5.1 is bettermore power to you
back to topic guys , we have a thread just for that 1jzvsna-t vs 2jzgte let's take the discussion to that thread.
![Name: IMG_20120609_165012.jpg
Size: 43.8 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/461217d1501791993-hey-1jz-guys-what-kinda-power-you-putting-down-img_20120609_165012.jpg)
#83
Regards 1jz naturals nobody brings them in to the country why would you, 2jzge bottoms are all over the place.
Several drag teams use GE blocks. squirters are only a benefit to cool stock piston skirts, and are not truly necessary, if you have them great if not don't cry its all good, but cost and availability due lend themselves as a definite benefit to GE bottoms.
#84
1jzgte
550cc injectors
mapecu2
walbro 255lph
soarer r154
489whp on my tune
1jzgte
440cc injectors
safc
walbro 255lph
auto with shimmed trans
374whp
1jzgte
rebuilt stock head
new air filter
440cc injectors
mapecu3
aeromotive 340lph
? whp im guessing around 400 even. injectors are holding me back though
i only have proof of the 2nd one. the 1st one was my old car dynoed by the new owner on my tune before he took off the manifold and turbo to go t4.
550cc injectors
mapecu2
walbro 255lph
soarer r154
489whp on my tune
1jzgte
440cc injectors
safc
walbro 255lph
374whp
1jzgte
rebuilt stock head
new air filter
440cc injectors
mapecu3
aeromotive 340lph
![](https://sphotos.xx.fbcdn.net/hphotos-ash4/432201_10150643126354544_381773007_n.jpg)
#86
1jzgte
550cc injectors
mapecu2
walbro 255lph
soarer r154
489whp on my tune
1jzgte
440cc injectors
safc
walbro 255lph
374whp
1jzgte
rebuilt stock head
new air filter
440cc injectors
mapecu3
aeromotive 340lph
550cc injectors
mapecu2
walbro 255lph
soarer r154
489whp on my tune
1jzgte
440cc injectors
safc
walbro 255lph
374whp
1jzgte
rebuilt stock head
new air filter
440cc injectors
mapecu3
aeromotive 340lph
#87
the first was a real garrett 60-1 .70ar
the second was driftmotions 60-1 .70ar (read Chinese 60-1 because it failed in 6 months)
the third is currently on the DM 60-1 but i just bought a Borgwarner s362 .81ar
#89
Thanks. I'm so excited to get it ^.^
440cc Through a auto. Honestly the numbers are pretty impressive. My bottle neck in the system is the injectors. I plan on getting mk4 550s again or try to find these denso 680cc side feed high impedance injectors I had at one point. There so damn hard to find.
