What tire size? 19x8.5 19x10
#31
Dude the offset don't matter are you guys stupid? the offset don't chage the tire and the way it looks on a rim. Those were just on there for winter I am running a 265/30/18 now in a Yokahama Advan A048. Those tires were on my MKIV. Anyways the offset is how far the rim is from the center of the wheel. Mine are -5. The offset makes no difference in the way the tire looks and thats what a 275 will look like on a 10" wheel thats why I posted that. Now OP run a 255 stretch and it will look great 265 will look ok. If Advan A048 came in a 255 fitment I would have them. You guys are missing the point. Now the offset matters on the way the wheel sits under the wheel well and how the tire will rub so you run a stretch tire. To all the Hellaflush kids on here that don't understand wider tire for better traction as well. Stretch tires look go no practical use tho and my car is not vip so I want traction anyways. Use over looks!!!!
P.S. You would have never seen stretched tires and thought they looked so cool if negative offset progression hadn't brought that style into the mainstream.
#33
1UZFE/2JZGTE
^^We all know the offset doesn't change the way a tire looks on the rim, no need to call anyone stupid. The point being made is that the offset affects which tire you chose for that rim. High offset you can go with wider tires low offset you need smaller tires. I ran 265/30/19 on a 19x10+19 setup now I'm running 18x12 with 5Xmm offset and I have 315/30/18's.
#36
Haha alright man slow down and read for comprehension. Offset DOES matter when it comes to what size tire will fit on the car. Nobody said it changes how it looks on the wheel. You even said yourself "Now the offset matters on the way the wheel sits under the wheel well and how the tire will rub so you run a stretch tire". This is of course wrong because if the wheel doesn't fit correctly with an appropriate sized tire then you bought the wrong offset for the width of wheel you purchased. A 10 inch wheel will fit CORRECTLY anywhere between a 275 and a 305. Yes correct means no stretch- it's unsafe, is outside of the manufacturers specifications of a SAFETY DEVICE (yes your tires are a safety device) and honestly looks juvenile because again your diminishing function for the sake of form (or at least what you think looks good).
Clear now?
OP.... I hope you laughed off the 255 suggestion!
Clear now?
#38
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
#39
Thanks, but you forgot to reference wiki on that. Here's how tires were originally designed to fit wheels. Feel free to hate generously.
Photo-0042.jpg?t=1304380916
#41
#43
I agree with you Bartledoo.........
What is the point of having wide wheels if you are not going to maximize the amount of rubber that you put on the ground? Why use stretched tires and leave your very expensive wheels (wheel lips) exposed to the first curb that you park next to? All for the sake of "tucking" your tires or "laying frame"? I think that I am just too old.........
