What tire size? 19x8.5 19x10
#76
#77
#78
THANK YOU FOR YOUR HELP...
#79
H&R was I think the first company to offer hub centric spacers for supras/SCs and they recommended extended studs only on spacers above 5mm- so you should be good to go, just make sure you get some good lugs that will "bite" into the wheel if that makes sense
#80
that the other problem, the stock "style" lugs wouldnt even go into the lug hole on the new rim......what do you recommend?
#81
might roll with the 265/35/19 3.65-3.7" sidewall
235/40/19 3.7" sidewall
i even thought about 225/40/19 up front which has a 3.5" sidewall
265/30/19 3.1-3.2" sidewall
235/35/19 3.23-3.3" sideall
#83
Fuzion.. you may not even need a roll..
https://www.clublexus.com/forums/sc-...sc400-223.html
Check out my postings on the last page. I am running 19x8.5 +15 in the front and 19x10 +20 in the rear. 245/35/19 front and 270/30/19 for the rear. Rolled the fenders and the fronts are fine, the rear I still rub a little, but going to get my camber adjusted some to clear.
#84
#86
you have any close up shots, i really want to see how thick that rear tire is gonna be...because im thinking of going with either a 255/265 tire... also how close was your speedo with the 245/35 tire up front?
#87
as for the speedo, couldn't confirm or deny due to 2 reasons:
1 - speedo being off wouldnt bother me
2 - my speedo connection is slightly loose causing the speedo to jump around (need to fix that)
#88
well the only reason i ran that rear tire size is because they came with the wheels, but if not i would i have ran a 255/35 or 40 or 265/35 or 40 (these would be too tall and definitely would rub regardless.. The thickness of the tire is very decent.. A 275/30 tire is about 83mm of a sidewall.. So for me, the height of the tire wasn't so bad to change it immediately..
As for the speedo, couldn't confirm or deny due to 2 reasons:
#89
#90
will the new camber bolts allow you further neg camber adjustments then stock?
