Help, Problem with Radio and Power Mirrors
Hi, I searched but couldnt find a answer but I recently had a guy replace the starter on my 95 sc400 after this repair, My radio will not power on and my power mirrors no longer work. Can someone help me with this? i checked fuses and they are fine. i asked the mechanic about it and he said all he did was replace the starter. He is a older guy so of course, he doesnt know anything about Lexus radio.
I had the same problem, fuses all good, but still no power. Check your driver's side wheel well. you might have broke a wire. pull back the splash guard, there is a harness that sits right above the wheel. check that harness, carefully separate the wires; you will find your problem. If i can remember, i think it is the thick green one.... GL....
Fairlane62
06-01-08 10:45 AM
